video of how to start making motion profiles
Here you can share and ask information about creating profiles in general (non game specific)
Postby motiondave » Sat 21. Jul 2012, 01:35
here is a video of starting to make motion profiles.
http://www.youtube.com/watch?v=PQaKTaKEvCo
I use the example of rfactor, but you do the same out of any game. If the games does not have AI, just drive it your self.
If you find the number too high and the motion too soft, reduce the number .
Re: video of how to start making motion profiles
Postby Babykuni » Sat 21. Jul 2012, 05:43
excellent Dave...Thanks something i can understand...lol..(pictures) now all i have to do now is get the k8055..sabertooth to work. :D
Babykuni
Postby motiondave » Sat 21. Jul 2012, 05:49
you are welcome. I thought it was high time to do some actual videos. I just had to understand the program myself properly.
As for the K8055, dig through the threads here. I know a few got it sorted.
Postby boons4 » Fri 27. Jul 2012, 17:03
Great stuff motiondave! Thanks a lot! How I hope I have seen this before I wasted so many hours trying to figure out what is maths setting haha.
boons4
Postby jsmith2307 » Fri 17. Aug 2012, 16:37
Greetings, :D
Great work!! How about one for Flight Simulator 2004, I've been working on that for about a month, I've got nothing to write home about, I could sure use some pointers!
jsmith2307
jsmith2307
Images: 8
Has thanked: 12 times
Postby motiondave » Sat 18. Aug 2012, 00:19
jsmith2307 wrote:Greetings, :D
jsmith2307
As said, use the same principle for any game with an existing plugin.
I am not sure about flight sim 04, you may need to use the graphics driver for this.
I am still currently working out that myself.
Postby jsmith2307 » Sat 18. Aug 2012, 16:47
Greetings,
Thanks for your reply, I think you are correct, I tried to duplicate your set-up and I can't get a graphics driver to show up on my screen ! Very perplexing... :D
jsmith2307
jsmith2307
Images: 8
Postby tronicgr » Sat 18. Aug 2012, 17:47
The graphics driver is available with stage2 key. Read the term of private use on how to obtain such a stage2 key.
Postby museumsteve » Fri 9. Nov 2012, 03:31
Excellent video Dave..many thanks for doing that.
I honestly never knew about adding value to the 'max' to mellow out the harshness. I'm looking forward to trying it out tomorrow and make some new profiles :)
museumsteve
Postby Riton » Thu 13. Dec 2012, 17:28
I have a hard time to understand how to find a specific reference to the values ​​of effects.
I watched the video of course.
What is the auto adjustment?
just to give an idea of ​​the range of effects?
value auto saves this value range, then you double changing the "1" with "2"
it is difficult to obtain a value auto repeatable and reliable.
you drive maximum performance from the car, if you drive gently values ​​are not correct, if you drive with accidents values ​​are false.
what is recommended?
thank you
Français
j'ai beaucoup de mal pour comprendre comment trouver une référence concrète sur les valeurs des effets.
J'ai regardé la vidéo bien sur.
A quoi sert l'ajustement auto ?
juste à donner une idée de la plage des effets?
la valeur auto enregistre cette plage de valeur, ensuite tu la double en modifiant le "1" par un "2"
il est difficile d'obtenir une valeur auto répétable et fiable .
il faut rouler au maximum des performances de la voiture, si on roule doucement les valeurs ne sont pas correcte, si on roule avec des accidents les valeurs sont fausse.
qu'est ce qui est conseillé?
Merci
Riton
Images: 70
Been thanked: 16 times
Return to Creating motion profiles
