This is how I have it * It would help if I ground the PC so the simulator is grounded via the serial cable?
If not, is there any other way as just ground the Simulator Frame?
regards!
poteroa wrote:Hi RafBR.
It would help to know what different ways you could do it, meaning do you have ground in your house/flat (the green/yellow cable inside the powersockets), watercirculated heating system is always grounded to earth. If you have any of those, you can ground the frame there
poteroa wrote:but do not ground the motors or the AMC directly to yellow/green or the battery, can´t say if its very good idea...
poteroa wrote:If you get pikes from the frame when you sit there, one way to ground the frame is to stick a copper pipe/bar in to ground in your backyard and run a cable directly to your frame.
poteroa wrote:Do not leave the copper/wire in open air, otherwise you might get a problem when there is a lightning and a storm.![]()
poteroa wrote:Oh, and before doing this, make sure your motors are insulated from the frame!
poteroa wrote:And if you don´t have experience with high voltages, and its illegal to mess with power sockets in your country, let someone with experience do it. I will take no responsibility if you burn your house, kill yourself, or break the electronics of your sim.
