force injector.
force injector.
Postby TMarcus68 » Fri 14. Sep 2012, 17:50
First of all i'm new here so pardon me with all the noob questions i might ask.
I'm trying to pull data for rpm, gear and speed for need for speed: Underground 2.
I've manage to find the rpm but ended up with 2 address. Also I've found the gear address but it's in String instead of bytes so does that matters? Also i cant seems to find the speed. All of the above i'm using cheat engine to aid me.
Next thinking that I've got the addresses and following them manual, i'm suppose to use the force injector, but i cant seems to find the application/plugin any where from the stock installation i download off this forum.
Any help will be greatly appreciated.
Thank you all in advance!
TMarcus68
Re: force injector.
Postby sirnoname » Fri 14. Sep 2012, 20:45
How about to get a stage 2 key with your project and simple activate the graphic driver?
Re: force injector.
Postby TMarcus68 » Sat 15. Sep 2012, 06:02
Does this means that the Force injector and stuff is only in Stage 2? But also currently my project is only for speed rpm and gear, no motion yet due to cash flow tightness. Would i still qualified to a Stage 2 key? Intending to use the data capture via symprojects gauge.
Thank you very much
TMarcus68
Re: force injector.
Postby davidbilla » Mon 29. Oct 2012, 06:57
thanks for this keys
davidbilla
Return to Need For Speed
