GRID - does it still have issues?
Postby motiondave » Sat 26. May 2012, 02:19
Hello all, I have been trying to get racedriver GRID to get working, but I am still getting crashes going back to the menu or loading into a race. I am aware that codemasters have bugs in the game so we are having issues. So at this time, I have un-installed it and put it in the draw.
I have a BOXED version 1.0 on dvd of the game.
Is anyone else playing this game?
If so, what plugin are you using? LFS? Codemasters? RD Grid?
Is there a line of code change? If so, what code change is it?
Did you have to apply any patch updates to get it to work, if so, which one (s)?
Is the game crashing to black screen at any time?
What operating system are you using?
Yes I know its an "arcade" style game, but its still a game that is supposed to be supported by x-sim 3, so hopefully someone can enlighten me to get it to work.
Thanks, David.
Re: GRID - does it still have issues?
Postby Riton » Tue 29. May 2012, 16:28
I use Live4speed plugin.
I just test one or 2 race, for the moment, no problem...
Riton
Images: 70
Been thanked: 16 times
Postby motiondave » Wed 30. May 2012, 00:11
Riton wrote:I use Live4speed plugin.
Thanks for that, but what line of code change do you use?
Also, I was getting one or two races as well, and it still had issues crashing.
Postby Riton » Wed 30. May 2012, 08:07
motion enabled="true" ip="127.0.0.1" port="4123" delay="1" extradata="0"
as I've told you, I conducted two races just to test. I did a fresh install of XSIM3, now it's ok, if you want, I'll test tomorrow any longer, and in the coming days
Riton
Images: 70
Postby motiondave » Wed 30. May 2012, 14:25
Riton wrote:motion enabled="true" ip="127.0.0.1" port="4123" delay="1" extradata="0"
Thanks Riton for your help. No worries about testing further, I will give it a thrash over the weekend
Postby motiondave » Thu 14. Mar 2013, 02:23
I am still having issues running GRID. Version 1.0 genuine disc.
It is a fresh install on a fresh PC.
I have tried LFS plugin and code change, it still black screen crashes after a race going back to main menu. But I have motion
I tried the RD Grid plug in but as there was no information on a hardware config code line change, I got no data in converter.
So what plugin do I use and what line of code change (if I need one) do I use?
Postby Riton » Thu 14. Mar 2013, 09:01
it worked as before.
I moved for house construction, the simulator is currently dismantled ...
I can not give you more info ...
Have you tried with the graphic driver?
Riton
Images: 70
Postby motiondave » Thu 14. Mar 2013, 13:41
it works with LFS plugin, but crashes for me going back to the main menu, I am trying to find out if there is another plug in that can be used.
There is a RD Grid plug in , but I want to know what the line of code change is.
I wasnt planning to use the graphics driver with it if I can avoid it, it is supported.
Re: GRID - does it still have issues? ANSWER ME!
Postby motiondave » Sat 16. Mar 2013, 00:39
I am bumping this as apart from Ritons assistance, no one is answering.
If no one likes GRID, fine, but for goodness sake, surely someone can help advise me in an exact way it gets set up.
Not just a (it works for me).
That doesnt help me,
Now , again, what plugin works best?
Do I need to copy paste plug in?
What is the line of code change?
Postby sirnoname » Sat 16. Mar 2013, 01:54
<motion enabled="true" ip="127.0.0.1" port="20777" delay="1" extradata="1" />
For the Codemaster plugin.
Return to Race Driver: Grid
