iRacing
iRacing
Postby rizzo20 » Sat 28. Apr 2012, 04:25
Lots of people over @ iRacing are using x-sim with great results, but I can't get it to work. I can't get past setting up the extractor (v 3003) . After pointing the extractor to the iRacing exe , the dropdown box for plugins does not list iRacing, nor does the telemtry plugin show up in motion driver. Someone sent me an iRacing plugin and I placed it in the x-sim/plugin folder and it still does not work. Any ideas?
rizzo20
Re: iRacing
Postby leonpo » Sat 28. Apr 2012, 07:44
Rizzo20 hi
We are waiting for the new beta I racing plugin. Sirnoname mentioned next week. I have also tried previous version plugin with no success. Probably the interface was changed. Hopefully it will also use new Iracing sdk.
Regards
Leon
leonpo
Re: iRacing
Postby shannonb1 » Mon 7. May 2012, 17:23
Do we have any update on this?
shannonb1
Re: iRacing
Postby leonpo » Tue 8. May 2012, 21:23
I am testing the beta plugin right now and it is looking good. It is up to Martin to decide it when to publish
Regards
Leon
leonpo
Re: iRacing
Postby shannonb1 » Wed 9. May 2012, 16:51
Is there a chance I can get included in the beta test? Im using wiper sim and still using the sender program from 2.0 wiht the profiler from 3.0
shannonb1
Re: iRacing
Postby tronicgr » Wed 9. May 2012, 18:08
shannonb1 wrote:... and still using the sender program from 2.0 wiht the profiler from 3.0
:? How did you manage that??? :lol:
Re: iRacing
Postby shannonb1 » Wed 9. May 2012, 19:12
have them both installed, i run 2 machines. Installed to different directories. set ip and the norm
shannonb1
Re: iRacing
Postby sirnoname » Wed 9. May 2012, 21:08
iRacing is published with 3.0.0.5!
Re: iRacing
Postby shannonb1 » Thu 10. May 2012, 22:23
tested it last night, loaded up a profile or 2. Mine seems to be pretty detailed compared to the others so Wiper guys, check it out.
shannonb1
Re: iRacing
Postby boons4 » Wed 27. Jun 2012, 11:12
Hi guys,
I also intend to use xsim for iracing only. When I use xsim2 there is a profile for us to download then in the software we click load this particular file. May I know where to download this file? So that it is a base file for me to fine tune? I am really confuse on how to use as so far I only using xsim2 for bass shakers output only..in future will be for full motion.
boons4
Return to iRacing
