Iracing not working since last update?  Topic is solved solved with post #18954
Re: Iracing not working since last update?
Postby sirnoname » Tue 8. Mar 2016, 22:20
Look into forums if s.o. did a new telemetry API. But this would be uncommon if something is running fine.
Been thanked: 128 times
Re: Iracing not working since last update?  Topic is solved
Postby spyderwash » Tue 8. Mar 2016, 22:31
I found the news
- Legacy telemetry (NR2003 Telemetry) is now disabled by default. It can be turned on again in the "app.ini" file by adjusting the "enableLegacyTelemetry=1" option. This interface is deprecated and will be removed from the sim next season.
it seems that something has changed in telemetry
spyderwash
Postby spyderwash » Tue 8. Mar 2016, 22:45
ok solved reactivated telemetry and everything works
spyderwash
Postby nicotriv » Tue 8. Mar 2016, 23:33
also for me don't work :(
nicotriv
Postby nicotriv » Tue 8. Mar 2016, 23:37
i'm sorry, where i can find the app.ini file? thanks
nicotriv
Postby spyderwash » Wed 9. Mar 2016, 00:33
C:\Users\.......\Documents\iRacing
spyderwash
Postby aitorjudez » Fri 11. Mar 2016, 01:30
I'm with the same problem since the last iracing actualization, after read the coments here, i'm sure that's a x-sim problem, i hope the will be repair soon
aitorjudez
Postby sirnoname » Fri 11. Mar 2016, 09:09
read above!
Return to iRacing
