Traction loss with scn5
Postby lyspatrioterace » Wed 9. May 2018, 22:28
hello i got a 2 dof scn5 playseat for a couple of years now and i would like to ad a 3rd actuator for traction loss.
i plan to instal my actuator horizontaly to move my seat left and right when i loss traction. My 3 actuators are working and plug in
but i have dificuty fugure out how to make it work in the profile. So i cheate a 3rd axis using the 3rd actuator , i understand that i need to look for Yaw, but in the converter when i use the Yaw effect 29 i got nothing. if i use yaw acceleration effect 32 i got motion but it move all the time. I want some motion only when i loss traction what should i do?
thank you
lyspatrioterace
Re: Traction loss with scn5
Postby spyderwash » Thu 10. May 2018, 12:13
put a higher value in the minimum force
spyderwash
Postby lyspatrioterace » Thu 10. May 2018, 17:16
thank you i will try that
lyspatrioterace
Postby lyspatrioterace » Tue 15. May 2018, 02:34
Do you mean the same value max and min on positive and negative or just positive? or higher number for positive and use force 29 yaw not 32 yaw acceleration?
thanks for the imput
lyspatrioterace
Return to rFactor & rFactor 2
