Check the first post in this thread
http://isiforums.net/f/showthread.php?t=20802
in rfactor2 you not need to rename rfactor2.exe but you need to change the rfactor2.exe path in extractor
profetadelmus wrote:in rfactor2 you not need to rename rfactor2.exe but you need to change the rfactor2.exe path in extractor
backupmichi wrote:Now i have tryed that the rafctor 2 laucher should start the 32bit exe of the game.
With the 32 bit exe the plug sign in the left upper corner in the game is there after few secounds the converter show me the correct values.
The Problem is only in the 64bit version.
But the 64bit exe works much better for me.
Maybe someone know why this would not work with the 64bit exe.
delay8ms wrote:For me it worked. But during the game, the game crashes and a Windows error message appear freezing the past values of X-Sim. I use Windows 8.1 and do not know if it was an Windows update problem or if it happens since I update to biuld 798.
