Autoscan rFactor 2 Issue
Postby nclabs » Sun 13. Apr 2014, 19:42
I followed the advices in the topic up here, I added manually the rFactor2.exe with the rfactor plugin, I added the dll in the plugin folder of rFactor 2, but when I start the game X-Sim doesn't recognize it and it doesn't start the motion. I tried to find a solution without luck. Did I miss something, or X-Sim can't recognize it anyway? Thank you for the help.
nclabs
Re: Autoscan rFactor 2 Issue
Postby prodigy » Mon 14. Apr 2014, 00:40
I think it wont work with rfactor2.exe file because the game needs to be started from it's launcher, so X-Sim need to start launcher when you press play. Autoscan cannot find your rf2 game? Can you try adding rf2 launcher.exe instead of rf2.exe file and try again? Have you double checked that rfactor plugin is checked in 'motion driver' settings?
Postby nclabs » Mon 14. Apr 2014, 15:41
I will double check everything, but I think it's already in the right place. I may try the launcher, but I need the autoscan function, because I have a lot of batch and automated executable sequence. Thank for your help anyway, if I pull out something I will write it down here.
nclabs
Return to rFactor & rFactor 2
