RFactor 2 Plugin
RFactor 2 Plugin
Postby sirnoname » Thu 21. Jun 2012, 17:51
Hello,
because the game is a beta here is a plugin for this beta.
Open the extractor, open the game wizard and select with ... your rfactor 2 executable.
Choose the rfactor plugin and add the game to the game listbox.
Now you must copy the atached plugin file to your rfactor 2 plugin folder.
Thats all.
There are reports that the motion will begin 5s after the race has started. This might be changed in Rfactor2 release version.
XSimRF2PluginV1.zip
(37.48 KiB) Downloaded 3434 times
Re: RFactor 2 Plugin
Postby kevin123 » Fri 22. Jun 2012, 16:10
Hello sirnoname
So I am sure that something wrong .... but do not know what .....
I tried the exe of the game manual search Extractor and select the plugin rfactor then I copied the plugin your plugin folder XSimRF2Plugin.dll rfactor2
Extractor and select the game I used to leave the two alerts
I click yes to both I did other tests and also by clicking No to the two notices did not go the same
Start the game with game play and not go even if the movement around the whole track ...
I tried other profiles, but those thinking they were giving me error with 7 and 9 with
I'm going crazy trying to get it to work it off?
Thanks for the help
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Postby sirnoname » Fri 22. Jun 2012, 17:09
What is the rfactor2 executable name?
Postby kevin123 » Fri 22. Jun 2012, 17:30
Yes RFactor 2
kevin123
Images: 132
Postby sirnoname » Fri 22. Jun 2012, 18:45
Please tell me the game executable.
Postby kevin123 » Fri 22. Jun 2012, 18:52
game executable: rFactor2.exe
kevin123
Images: 132
Postby sirnoname » Fri 22. Jun 2012, 19:29
Copy the above plugin to your rFactor2/plugin folder. (not in the X-Sim folder)
Add manually the rfactor2.exe executable to your game listbox.
select this game out of the right dropdown box.
you have to press twice yes.
Press play to start rfactor 2 and look at your converter input setup if there are moving values if you are inside a race.
Postby kevin123 » Fri 22. Jun 2012, 20:19
Copy the plugin above rFactor2/plugin folder. (not in the X-Sim)
I copied it in C: programfiles(x86)/rfactor2/plugin
Manually add the executable to the listbox rfactor2.exe game.
select this game out of the box right down.
you must press two times yes.
Done
Press play to start rfactor 2 and look at the configuration of your drive if you input the values ​​if you are moving within a track is
Do you say this?
I walked around the track but I do not see any movement of values
kevin123
Images: 132
Postby motiondave » Sat 23. Jun 2012, 00:58
Try looking at the math screen, put in a force or two on each axis , let it auto max adjust, then see if any numbers come up. You do not need to simulator moving to see this, just click "play game" then look at the math section.
Postby kevin123 » Sat 23. Jun 2012, 19:36
Fixed at last! ;)
I moved the whole plugin folder in C: \ Program Files (x86) \ rFactor2 \ Core
and was first in C: \ Program Files (x86) \ rFactor2
Big Thanks sirnoname for the help and the plugin
motiondave thanks to the response
Regards kevin
kevin123
Images: 132
Return to rFactor & rFactor 2
