Problem rfactor 2 no movement
Postby kevin123 » Wed 20. Jun 2012, 17:26
using the version 3 of x-sim I select the plugin rfactor but no movement or tried different profiles
I doubt the plugin compatible with rfactor rfactor 2?
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Re: Problem rfactor 2 no movement
Postby RafBR » Wed 20. Jun 2012, 22:57
kevin123 wrote:using the version 3 of x-sim I select the plugin rfactor but no movement or tried different profiles
With x-sim 3 for rFactor 2 I must click "play" for it to work. "Try to send data" is not enough.
RafBR
Images: 24
Postby sirnoname » Thu 21. Jun 2012, 02:13
Rfactor 2 has its own plugin.
Try send and autodetection are working.
The next beta have most of the plugins available again.
Postby kevin123 » Thu 21. Jun 2012, 11:26
@ RafBR
I click on play I always try not to send data to start the simulator does not work yet ... and just a matter of plugins as I imagined because I usually do an automatic search of the game and in this case does not find it and even if I do not work in manual
@ sirnoname
Sorry sirnoname but are impractical .... the custom plugin I find somewhere to download? Or you have to write it specifically?
Should I wait for the next beta? so it is automatically also because I would not know how to write a plugin to do this if it were
Many thanks for the answers
kevin123
Images: 132
Return to rFactor & rFactor 2
