Dirt showdown works....and sorting issues
Postby motiondave » Thu 7. Jun 2012, 09:54
Hello, Dirt showdown works for motion with dirt2 plugin and code change, but the game crashes right at the end of the first race of the tour, requiring a program restart.
It shows a 10038 socket error. I have tried forcing dx10, running game as admin and xp mode.
Any ideas?
Re: Dirt showdown works but game crashes
Postby museumsteve » Thu 7. Jun 2012, 12:03
That was the same error that DiRT 3 had after the last update and was never fixed. Only way to fix DiRT 3 was to bin the update, but of course you cant do that with DiRT Sowdown :(
museumsteve
Postby museumsteve » Thu 7. Jun 2012, 12:17
I had a look on Codies site, going back to the DiRT 3 issue and it seems patch 1.02 is the one that killed it for motion/x-sim..and here's a line in the description in the update that probably did it..I assume it fixed something for D-Box owners perhaps..
Physics output to motion simulators is now correctly faded out at the end of a race, preventing some situations within which motion would continue after crossing the finish line.
I would assume whatever they did for that is the same for Showdown as it's also listed as a D-box game.
museumsteve
Postby motiondave » Thu 7. Jun 2012, 13:07
mmmm.....curly one then....I will try LFS plugin to see if that works.
Pity codemasters have crapped the game motion again, or just wrote it for d-box.
Postby museumsteve » Thu 7. Jun 2012, 13:12
It's the only reason I gave up on DiRT 3...very frustrating :(
museumsteve
Postby Riton » Thu 7. Jun 2012, 13:47
with DIRT 3 I use " Live4speed" plugin and this configuration:
<motion enabled="true" ip="127.0.0.1" port="4123" delay="1" extradata="0"
it works, maybe it will work for you too for Dirt Showdown
Riton
Images: 70
Been thanked: 16 times
Postby motiondave » Thu 7. Jun 2012, 14:19
Riton wrote:with DIRT 3 I use " Live4speed" plugin and this configuration:
RIghto thanks, I will give it a whirl tomorrow.
Postby sirnoname » Thu 7. Jun 2012, 14:30
What happens if you change your hosts file entry in dbox 127.0.0.1?
If you do not change the "original" config file and change the X-Sim plugin to simulate a D-Box it should work? (must be the one after game installation)
I only think that there is some money behind this support.
If this also fails perhaps a dbox forum gives some more answers, would be fine to get it working and we can change the auto install scripts for it.
Postby motiondave » Thu 7. Jun 2012, 14:46
Ok trying to make sense of this Sir
What hosts file?
So I would choose x-sim plugin as standard and leave hardware config standard?
If this also fails perhaps a dbox forum gives some more answers, would be fine to get it working and we can change the auto install scripts for it.[/quote]
I will look into dbox as well.
I am also going to try LFS plugin as well.
I will let all know of results
Postby sirnoname » Thu 7. Jun 2012, 14:54
As far I know the LFS plugin will work better but has some other hangups on other positions or it differs from track to track.
To find this out I created a beta test but the testers did not verify the correct setup, only the first values of about 10 seconds.
It is a continous problem if we touch the file. If it is touched it hangs on game quit or if we play multiplayer. After a multiplayer race on GRID it hangs up for example.
Differs in Multiplayer, single player, patch version, game (Dirt/grid) and tracks.
Since dbox is standard entry and it is working I think this may be a solution because the game will work for all the others.
Perhaps the dbox is hardcoded somewhere inside the game and it will get in trouble with a touched config file.
Return to Dirt
