Dirt Rally 2.0 with VR - no telemetry  Topic is solved solved with post #24943
Postby assafxsim » Fri 4. Dec 2020, 17:04
When playing dr2 i can only get telemetry when using a screen.
When using a vr headset, I dont get the telemetry in the extractor.
The extractor recognise game is playing.
This is how I start the game:
Start steam vr.
Then start the game in the extractor app.
Then I get the message in the hmd that i am trying to launch without vr.
So i press cancel (inside the hmd).
Extractor is "waiting for game to launch..."
And then I launch the game inside the hmd in vr mode.
Extractor says "game detected", but there is no telemetry.
Thanks for the help
assafxsim
Re: Dirt Rally 2.0 with VR - no telemetry
Postby sirnoname » Sat 5. Dec 2020, 11:30
The start procedure sounds wrong.
Use the motion driver game scanner instead of launching the game with extractor. Simple add exe, profile and game taskbar title for detection and enable the scanner to a green x-sim taskbar icon.
https://www.x-sim.de/manual/autoscan.html
For the VR+Telemetry problem you must ask the game developer.
Postby chafer » Wed 2. Jun 2021, 12:46
Same problem here, no telemetry in VR.
Have you found a solution ?
chafer
Re: Dirt Rally 2.0 with VR - no telemetry  Topic is solved
Postby chafer » Tue 8. Jun 2021, 16:14
Disregard, I have found the solution : there is another hardware_settings_config.xml to edit : the one with VR !!!
chafer
Postby BlancatM » Mon 4. Dec 2023, 13:43
chafer wrote:Disregard, I have found the solution : there is another hardware_settings_config.xml to edit : the one with VR !!!
Hola amigo, tuve la fortuna de lanzar DIRT 2.0 desde x-sim sin tener que modificar hardware_settings_config.xml en el modo normal sin VR.
Pero al inicial en VR efectivamente me quedo sin movimiento... podrias por favor indicarme la ruta del VR hardware_settings_config.xml que debo modificar... GRACIAS
BlancatM
Return to Dirt
