DIRT2 plugin problems  Topic is solved solved with post #87
Postby motiondave » Sat 24. Mar 2012, 11:23
Hello all, I am having issues with DIRT2 PLUG IN. I noticed that if I look at the outsim screen of dirt two, the game paused box is ticked, I cannot untick that even when I start and play the game. Its like it is stuck on game paused. And so I cannot get any data out of the game to create profiles.
Any ideas as dirt2 plugin is used for games dirt 2,3 f1 2010, f1 2011.
Cheers, David.
Re: DIRT2 plugin problems
Postby sirnoname » Sat 24. Mar 2012, 13:44
Please use the bugtracker!
Postby motiondave » Sat 24. Mar 2012, 13:51
sirnoname wrote:Please use the bugtracker!
Sorry to sound stupid, but where is the bugtracker please?
Postby sirnoname » Sat 24. Mar 2012, 13:58
forum portal -> report a bug ;)
Postby motiondave » Sat 24. Mar 2012, 14:00
sirnoname wrote:forum portal -> report a bug ;)
Thanks for that, I will report it later, must sleep........
Postby jerm138 » Wed 11. Apr 2012, 16:54
Was a solution ever found?
I saw a bugtrackerfor Dirt2 but it was closed and I didn't see a solution there either. Not sure where the discussion went after that.
I'm having the same problem with the plugin... the extractor doesn't seem to be getting any values from the game.
jerm138
Postby motiondave » Thu 12. Apr 2012, 09:44
jerm138 wrote:Was a solution ever found?
Ok, let the extractor select dirt2/f1 when you create a profile in extractor. And just in case, select motion driver, standard setup, telemetry plug in and select dirt2/f1.
Also use this line of code in hardware settings
<motion enabled="true" ip="127.0.0.1" port="20777" delay="1" extradata="1"
Hope this helps
Postby jerm138 » Fri 13. Apr 2012, 00:47
Thanks Motiondave.
I don't see where I'm supposed to enter that line of code. I can't find "Hardware settings" on the Extractor anywhere.
Sorry for my n00biness.
jerm138
Postby motiondave » Fri 13. Apr 2012, 10:11
jerm138 wrote:Thanks Motiondave.
Use this one, replace it in the dirt 2 folder probably in a folder named my games, then look for dirt 2, hardware settings and copy/paste the file.
hardware_settings_config.xml
(1.59 KiB) Downloaded 2826 times
Postby kewin82 » Sun 23. Aug 2015, 17:59
questo e il plugin per dirt2
kewin82
Return to Dirt
