Richard Burns disconnect Converter
Postby deniscina78 » Thu 22. Nov 2012, 11:46
Hello guys!I need your help.My simulator now is really good!I'm happy but i have a problem with rbr plugin (x-sim 3.0.0.7). When i press PLAY GAME, richard burns start ok, the converter dialog with extractor only 3 seconds and then "Disconnected". I try to solved in many Ways but i don't understand wich is the problem,.
Thanks a lot and sorry for my english.
Denis
deniscina78
Re: Richard Burns disconnect Converter
Postby sirnoname » Thu 22. Nov 2012, 11:57
yes, because 3.0.0.7 does not support the launcher option.
This means if you start rbr you start the launcher which loads the rbr SSE executable. The rbr executable is then closed which lead to a extractor stop.
In 3.0.0.8 there is a launcher option which will wait for the main game.
You can pm me if you like to test this.
Postby sniegavirs » Mon 14. Jan 2013, 01:17
I found different way to solve this problem, no need for different plugin! Just add your game manualy in extractor, and when it is asking for your RBR game exe file path you need to show on RichardBurnsRally_SSE.exe NOT RichardBurnsRally.exe and everything works great!
When launching RichardBurnsRally.exe it actualy runs RichardBurnsRally_SSE.exe and that's what causes the extractor deactivation.
sniegavirs
Images: 16
Postby dalantaibaatar » Wed 16. Jul 2014, 16:12
hi i have one problem, and extractor don't work on RBR i attached capture
dalantaibaatar
Postby sirnoname » Wed 16. Jul 2014, 21:28
Enter something in the version box, it cannot stay empty. This setup step is removed in the next X-Sim Version.
Postby dalantaibaatar » Thu 17. Jul 2014, 13:41
hi i changed launcer file like this RichardBurnsRally_SSE.exe but extractor working fine when converter don't run. extractor don't work, can't call exe file when converter runing. X-sim3 version 3.0.2.9
dalantaibaatar
Return to Richard Burns Rally
