Motion Rig Hardware for Sale
Postby telfel » Sat 29. Nov 2014, 07:27
Hi
Due to illness i will not be able to finish or use my motion rig, so i'm selling the hardware.
Motion Control Products (5 pairs)
24 volt 590 watt 27 amp, DC motor with 25:1 Steel Worm Drive Gearbox
No load shaft speed 120 rpm @ 24 volt, 60 rpm @ 12 volt
19mm Left or Right Hand output shaft with 8mm bolt to fix feedback pot
All metal construction & gears
Four horizontal base mounting lugs
These motors are larger & more powerfull than the wheelchair buggy type
Including mounting plates to fit pot & micro switches to the back of the gearbox output shaft
Motors are new / old stock, never used slight blemish from storage £80.00 / Pair
Postage @ cost to Uk or EU
33103312331110463314
Sabertooth
Will drive 2x motors, @ 60 amp constant / motor, 120 amp peak / motor @ 24 volt H Bridge, 12 to 30 volt input
Kangaroo x2 Position Control Module, pot or encoder feedback, limit switch option
Auto Tune for position control. Current and temperature overload protection
Will drive two motors at a constant 60 amp, built in cooling fan / heatsink, metal base plate can
also be bolted to frame for extra heat sinking £120.00 Each
BI Tech 180 deg Hall Effect feedback pot £ 15.00 per pair
Postage @ cost to UK or EU
Dell Server PSU model No AA23290 12 volt 75 amp output
2 Can be run in parallel to give 12volt 150 amp
or Series with internal mod to give 24 volt 75 amp £5.00 each
3397
2 dof package 2 x motors, 1 x sabertooth / kangaroo, 2 x BI pots = £230.00 + 2x Dell psu free of charge
Payment by PayPal Gift
If you have any questions or require further informatin pm or email me (terryfelstead (at) gmail.com)
regards Terry
telfel
Images: 54
Been thanked: 9 times
Re: Motion Rig Hardware for Sale
Postby vicpopo » Sat 29. Nov 2014, 10:42
Hi Terry,
Hope you will recover your health soon !
Regards
