sli pro + x-sim + LFS
Postby abs2 » Wed 10. Jul 2013, 15:18
hello I am trying to set an automated start (one click) of LFS.
i understand the command line has to be in the LFS shortcut ( /insim-29999). but i can seem to add this line in the LFS edit section of the extractor.
when i push the buton "play game" a messae pops up with "invalid command or something like that"
if i dont use a command line and press play game (+ start in the convercter), x-sim start but not the slipro.
if i use a the command line /insim=29999 in the lfs short cut , the LFS game and the sli pro start.
i belive my problem is the syntax of the command /insim=29999. any idea anyone?
thanks
abs2
Re: sli pro + x-sim + LFS
Postby sirnoname » Wed 10. Jul 2013, 17:41
The new extractor has two command line options.
One in the game listbox (left and global) and one on the right side (for profile based commands that might change like a map startup parameter).
Which one you are using?
Postby abs2 » Fri 12. Jul 2013, 06:46
hello thanks for the reply
i was able to solve or find a patch by creating a bat file as follow
cd c:\lfs\
lfs,exe /insim=29999
i created a new game called LFS with that bat fine in the far left window of the extractor (followed the standart steps but directing to the bat file instead to the lfs.exe file). when play game is pressed i still need to press the start button in the convector. but it is OK
thanks
abs2
