Buttkicker and Project Cars??  Topic is solved solved with post #17328
Postby GhostFace » Wed 9. Sep 2015, 13:13
Hi!!
I just received my Buttkicker Gamer2 and want to use it with Project Cars and X-Sim.
As for now, i followed some setup-guide for iRacing i found here (pdf) but i cant get any vibrations, nor do i get any Connection from the game i think...
Is there any Step-by-Step Tutorial out there on how to setup a buttkicker to work with PCars (and Assetto Corsa) ??
I´ve read that you later have to fine-tune the settings for the specific Outputs in Math Setup, and this could take a long time ... is this true??
If so, i am really thinking about buying *, because i dont want to spend ages just to get the buttkicker working :/
Pleease point me into the right direction, thx!!
GhostFace
Re: Buttkicker and Project Cars??
Postby Dazbolt » Mon 30. Nov 2015, 00:02
I also need help for the same games how did you fix your problem?
Dazbolt
Postby aedxsim » Wed 2. Nov 2016, 18:25
The most common reason for external software and devices not being able to read the in game telemetry is that you need to make sure that 'Shared memory' is turned on. I had this problem with a couple of the readout panels I had in my rig when I got pCars.
Btw have you found a decent profile for it yet?
aedxsim
Return to Project CARS
