Re: projectCARS
Postby minikase » Fri 22. Mar 2013, 20:27
They build a new subforum...here we go:
http://forum.wmdportal.com/forumdisplay ... Discussion
minikase
Re: projectCARS
Postby sirnoname » Fri 22. Mar 2013, 22:40
Sorry guys, in the current version of pcars the output is broken as reported in the forum and as I can confirm.
Re: projectCARS
Postby prodigy » Mon 25. Mar 2013, 19:59
Build 435 with fixed shared memory is live *.
Shared Memory:
* Restore gSharedMemoryManager.Update call
* Shared memory fix
Re: projectCARS
Postby sirnoname » Mon 25. Mar 2013, 20:04
All is working f....g good ;)
Local accelerations and slip with rotation velocities ...
The values seems to be correct sorted in. Autodetection with the game wizard is also working.
Re: projectCARS
Postby RafBR » Tue 26. Mar 2013, 06:07
Good, motion Works :)
It seems that roll and pitch are with some kind of spikes :?
I will run some more tests, I did not find a good track with some hills where I can take the car to test roll and pitch :mrgreen:
regards
edit:
the problem is definitely on the pitch
roll working fine
open wheelers are the great fun to me, road cars are too weird
overall game is great.
RafBR
Images: 24
Re: projectCARS
Postby yokoyoko » Wed 27. Mar 2013, 13:49
Yesterday I finally had some time for my first try ever of this game... -> I waited for a motion plugin.
Agree - some more some less. But really weird are the Karts! :?
I will keep trying the huge content of this game.
Here some impressions of my "lousy" first lap:
@ Raf - I have no spikes with roll or pitch.? Perhaps Sir had already filtered this in v3?
But I noticed that yaw (effect 28) is not "yaw". It is working like a compass at the moment! The values change on the "way" the car is positinoned on the track. Effect 32 could also not be used for a traction loss simulation atm because the values are proportional to the steering angle. ---> Anyone experienced the same? Has perhaps someone reported this to wmd - or does someone know the correct thread?
All other effects seem to work great!
Thx sirnoname for the plugin :!: :!: :!:
Re: projectCARS
Postby prodigy » Wed 27. Mar 2013, 15:20
Thanks for the video man, I was thinking when are you gonna post it :)
You should also put it on pCars forum, they would love to see some showcase.
I had some bad luck with my sim, for now I can only satisfy myself with Arduino Dashboard :D
Sirnoname told that some forces are world oriented, that's probably why they change as you change direction. It seems that it is working like using Graphic Driver, X Y Z..
Re: projectCARS
Postby yokoyoko » Wed 27. Mar 2013, 15:29
Hehe thx for your comment - prodigy ;) Unfortunately I have really limited time at the moment, so it took a bit longer. I even did not create a seperate profile for this video - my rafctor profile for f3 cars works great on the palmer jaguar of project cars. ;)
Would you mind to do this for me? Would be very nice of you!
As said above this month is not the best regarding sparetime. + I'm not so familiar with the wmd forum and never posted there...
Best regards
Re: projectCARS
Postby RafBR » Wed 27. Mar 2013, 18:39
yokoyoko wrote:@ Raf - I have no spikes with roll or pitch.? Perhaps Sir had already filtered this in v3?
Yes I use V3. The problem is on pitch, roll works fine.
When I enable pitch, sometimes my simulator seems that will throw me out of my room :o
Everything else working so good!
RafBR
Images: 24
Re: projectCARS
Postby yokoyoko » Wed 27. Mar 2013, 18:55
Can you pm me your math for pitch or is your profile in the cloud?
Return to Project CARS
