Re: projectCARS
Postby vicpopo » Thu 23. Jul 2015, 07:28
Ok fine thanks !
Have a nice holidays :D
Re: projectCARS
Postby vicpopo » Fri 14. Aug 2015, 21:17
sirnoname wrote:If you Start pcars with a launcher like steam or Xsim it is a child process of the launcher. So there is a taskmanager time period Problem because you get less cpu time. However this must be a type of raise condition because we use steam for a start. I check this after my holliday.
Hi Sir !
You seam to be back from holidays ? ;-)
Did you already checked something ?
Greetings
Re: projectCARS
Postby sirnoname » Sat 15. Aug 2015, 14:27
Hi, why you do not start from steam and let X-Sim autodetect pc-cars like shown in the presentation viewer video?
Re: projectCARS
Postby vicpopo » Sat 15. Aug 2015, 21:00
Hi , in fact never used the feature of presentation viewer and after watched the video very usefull feature. I use xsim like a noob !! But happy to test this way to launch pcars.
After done will report here what is the cpu load !
Re: projectCARS
Postby sirnoname » Sat 15. Aug 2015, 21:09
Go here, enter taskname and game name and a profile to load.
http://www.x-sim.de/manual/autoscan.html
It must tell you game detected if you have started the game.
Make the X-Sim symbol aktive in the tray area to start the scan.
Re: projectCARS
Postby vicpopo » Sat 15. Aug 2015, 23:34
ok will try after downloading pcars update from steam .
Re: projectCARS
Postby sirnoname » Sat 15. Aug 2015, 23:40
I will make some test tomorrow ...
Re: projectCARS
Postby vicpopo » Sun 16. Aug 2015, 01:21
tested but can"t launch the plugin game from steam !
the converter always stays off .
and when i click start on converter i have the message no game connection is available
I use just one PC win 7 64bits
Re: projectCARS
Postby vicpopo » Mon 17. Aug 2015, 13:31
sirnoname wrote:I will make some test tomorrow ...
Hi Sir ,
Did you have some news after testing ?
Greetings
Re: projectCARS
Postby sirnoname » Mon 17. Aug 2015, 22:15
So what do you want, what is the goal of this?
pcars64.exe with x-sim?
pcars64 started with steam and X-Sim?
or any pcars 32 bit solution with autodetection over steam?
tell me which and I tell you how!
Return to Project CARS
