Re: projectCARS
Postby spyderwash » Tue 2. Dec 2014, 10:58
you have to change with the new dll memory v5 on the previous page
spyderwash
Re: projectCARS
Postby mreiner » Thu 11. Dec 2014, 12:37
Hi
After quite some time I've again tried some laps in pCars yesterday.
Thanks to all the information in this thread I was able to get it work with XSim, but only the 32Bit Version (switch "-x86")
Is there any chance to get the 64Bit version to run?
Extractor keeps "Waiting for game to start" and doesn't recognize the game.
I also tried to create a separate profile with the pcars64.exe, but no luck.
mreiner
Images: 22
Been thanked: 15 times
Re: projectCARS
Postby sirnoname » Thu 11. Dec 2014, 14:23
Try this:
As exe use notepad, then start.
After notpad start pcars.
Re: projectCARS
Postby mreiner » Fri 12. Dec 2014, 11:51
Thank for the hint, that worked.
I wrote a small launcher prog, that takes the game exe as parameter, and waits until the game is stopped.
So I can use the launcher as exe in XSim, and don't have to fiddle with notepad.
mreiner
Images: 22
Re: projectCARS
Postby spyderwash » Thu 7. May 2015, 22:51
with the commercial release my plugin no longer works and can make the controls?
thanks
spyderwash
Re: projectCARS
Postby spyderwash » Fri 8. May 2015, 00:51
ok now works had not entered rungameid steam :oops:
spyderwash
Re: projectCARS
Postby rauls13 » Sat 9. May 2015, 13:01
hello anyone could help me run the project cars with x-sim 2dof the racerrom detects me and come and work with the rfactor but the Corsican assetto and project cars not and I have to do it by steam greetings and hope you can help me thanks
rauls13
Re: projectCARS
Postby piorck » Thu 14. May 2015, 23:41
bonjour , futur possesseur d'un simulateur dynamique t1000 de prosimu , je cherche un tutorial facile pour le faire fonctionner avec pcars ainsi que des led supplementaires .
j'arrive à faire fonctionner mes led sur rfactor .
piorck
Re: projectCARS
Postby mpobs » Fri 15. May 2015, 20:42
Hi!
I am trying to get x-sim extractor to work with Pcars, but i just can`t get it to connect with the game.
Extractor says
X-sim is waiting for the game
pCARS64.exe
and it`s executable
pCARS64.exe
It starts the game but the Extractor just stays in that step and i wont get values in the input section of converter.
I have V5 plugin in the use and my pcars patch is 1.0.1.3
I also have steam rungame id as steam://rungameid/234630
I`m bit confused what do you mean when you say: use notepad as exe
I know this is not a big problem but i am quite newbie with these, but this is the first game what i havent get running at all.
Thank`for the help
Mikko
mpobs
Re: projectCARS
Postby sirnoname » Sat 16. May 2015, 01:46
You cannot find a 64bit game process with a 32bit X-Sim ;)
In the converter program setup you see the list of all processes from 32 bit view.
You can do a workaround by starting 32 bit game or avoid steam start.
Return to Project CARS
