F1 2012 problem please help !!???
For all games in the F1 series: F1 2010, F1 2011, F1 2012 etc.
Re: F1 2012 problem please help !!???
Postby chris62 » Sun 14. Oct 2012, 21:37
nclabs wrote:Please sirnoname can you show us how to make working xsim with f1 2012? I tried but with no luck. Once I know how, I can make a short tutorial, and share it with all the forum. Thx
Hi
do you use the steam version?
Best regards
chris62
Postby nclabs » Mon 15. Oct 2012, 09:19
I have a non-steam edition, my desktop link have the exe in it, not the steam ID, but I've seen that in my installation folder there is a steam_api.dll. Maybe it's just some system file needed for starting the game, I don't * However, I was still not able to make the thing works.
nclabs
Postby chris62 » Mon 15. Oct 2012, 22:05
nclabs wrote:I have a non-steam edition, my desktop link have the exe in it, not the steam ID, but I've seen that in my installation folder there is a steam_api.dll. Maybe it's just some system file needed for starting the game, I don't * However, I was still not able to make the thing works.
Hi
have you changed all game configs. in my games?
chris62
Postby nclabs » Mon 15. Oct 2012, 22:19
This is my hardware_setting_config:
<?xml version="1.0" encoding="UTF-8" ?>
<hardware_settings_config version="46">
<cpu>
<threadStrategy parallelUpdateRender="true" workerMapFile="system/workerMap4Core.xml" forceFeedbackProcessor="3" dvdStorageProcessor="3" dataSetMonitorProcessor="1" renderProcessor="0" updateProcessor="2" fileStreamProcessor="3" />
</cpu>
<graphics_card update="true">
<directx forcedx10="false" />
<resolution width="800" height="600" aspect="normal" fullscreen="false" vsync="0" multisampling="8xmsaa" oldWidth="800" oldHeight="600">
<refreshRate rate="60" />
</resolution>
<gamma level="1.0" />
<textures lod="0" />
</graphics_card>
<shadows enabled="true" size="2048" maskQuality="1" />
<headlights headlightQuality="2" />
<particles enabled="true" wind="true" />
<crowd enabled="true" detail="1" />
<cloth enabled="true" detail="1" />
<groundcover mode="blended" clutter="true" />
<objects lod="1.3" maxlod="0" />
<trees lod="1.25" maxlod="0" />
<vehicles characterQuality="3" lodQuality="2" />
<envmap faces="6" size="512" forceBilinear="true" />
<water update="true" detail="2" />
<mirrors enabled="true" forceBilinear="true" width="1024" height="256" car_maxlod="1" car_culldist="300.0" />
<skidmarks enabled="true" />
<dynamic_ambient_occ enabled="true" />
<track_reflections enabled="true" />
<physics environmentalDamage="true" vehicleDamage="true" />
<motion enabled="true" ip="127.0.0.1" port="20777" delay="1" extradata="1" />
<led_display nativeSupport="true" />
</hardware_settings_config>
What do I have to change? Thanks you so much for your interest.
nclabs
Postby motiondave » Tue 16. Oct 2012, 00:21
did you try to copy paste the dirt 2 plug in out outsim into the program folder of f1?
Sometimes you have to do that.
You can find the dirt2 plug in and outsim in the plugins of x-sim.
The hardware file likes right.
Postby nclabs » Tue 16. Oct 2012, 08:21
What do you mean with "out outsim"? I noticed that in my installation folders the dirt2 plugin was missing, so I added it by myself, but nothing changed. I have even disabled the firewall, but no luck again. What's the next step?
nclabs
Postby nclabs » Tue 16. Oct 2012, 08:27
nclabs wrote:What do you mean with "out outsim"? I noticed that in my installation folders the dirt2 plugin was missing, so I added it by myself, but nothing changed. I have even disabled the firewall, but no luck again. What's the next step?
Maybe you mean that little client with the red icon! Nope, that one I didn't put in the installation folder, when I get back home I will try.
nclabs
Postby motiondave » Tue 16. Oct 2012, 14:09
Please see the picture attached...
Postby nclabs » Tue 16. Oct 2012, 14:21
Yes I did that, but it still don't work. I'm starting to think that is some installation problem, later I will remove everything and start all over again. Tonigh I will report any news. Bye
nclabs
Postby motiondave » Tue 16. Oct 2012, 14:23
try live for speed plug in....
<motion enabled="true" ip="127.0.0.1" port="4123" delay="1" extradata="0"
Return to F1
