Postby wallytattoo » Thu 31. Jul 2014, 05:20
Hola a todos, quería ver si me pueden ayudar, estoy atascado en esto y no se como salir. Les comento seguí el instructivo que me pasó sirnoname
http://www.x-sim.de/software.php?lang=eng&page=simulation_training
y estoy usando este código:
Code: Select all
   X-Sim PID
   This program will control two motor H-Bridge with analogue feedback and serial target input value
   Target is a Arduino UNO R3 but should work on all Arduino with Atmel 328, Arduinos with an FTDI serial chip need a change to lower baudrates of 57600
   Copyright (c) 2013 Martin Wiedenbauer, particial use is only allowed with a reference link to the x-sim.de project
   Command input protocol   (always 5 bytes, beginning with 'X' character and ends with a XOR checksum)
   'X' 1 H L C            Set motor 1 position to High and Low value 0 to 1023
   'X' 2 H L C            Set motor 2 position to High and Low value 0 to 1023
   'X' 3 H L C            Set motor 1 P Proportional value to High and Low value
   'X' 4 H L C            Set motor 2 P Proportional value to High and Low value
   'X' 5 H L C            Set motor 1 I Integral value to High and Low value
   'X' 6 H L C            Set motor 2 I Integral value to High and Low value
   'X' 7 H L C            Set motor 1 D Derivative value to High and Low value
   'X' 8 H L C            Set motor 2 D Derivative value to High and Low value
   'X' 200 0 0 C         Send back over serial port both analogue feedback raw values
   'X' 201 0 0 C         Send back over serial port the current pid count
   'X' 202 0 0 C         Send back over serial port the firmware version (used for x-sim autodetection)
   'X' 203 M V C         Write EEPROM on address M (only 0 to 255 of 1024 Bytes of the EEPROM) with new value V
   'X' 204 M 0 C         Read EEPROM on memory address M (only 0 to 255 of 1024 Bytes of the EEPROM), send back over serial the value
   'X' 205 0 0 C         Clear EEPROM
   'X' 206 0 0 C         Reread the whole EEPRom and store settings into fitting variables
   'X' 207 0 0   C         Disable power on motor 1
   'X' 208 0 0   C         Disable power on motor 2
   'X' 209 0 0   C         Enable power on motor 1
   'X' 210 0 0   C         Enable power on motor 2
   'X' 211 0 0   C         Send all debug values
   EEPROM memory map
   00      empty eeprom detection, 111 if set, all other are indicator to set default
   01-02   minimum 1
   03-04   maximum 1
   05      dead zone 1
   06-07   minimum 2
   08-09   maximum 2
   10      dead zone 2
   11-12   P component of motor 1
   13-14   I component of motor 1
   15-16   D component of motor 1
   17-18   P component of motor 2
   19-20   I component of motor 2
   21-22   D component of motor 2
   23      pwm1 offset
   24      pwm2 offset
   25      pwm1 maximum
   26      pwm2 maximum
   27      pwm frequency divider (1,8,64)
   Pin out of arduino for H-Bridge
   Pin 10 - PWM1 - Speed for Motor 1.
   Pin  9 - PWM2 - Speed for Motor 2.
   Pin  2 - INA1 - motor 1 turn
   Pin  3 - INB1 - motor 1 turn
   Pin  4 - INB1 - motor 2 turn
   Pin  5 - INB2 - motor 2 turn
   Analog Pins
   Pin A0 - input of feedback positioning from motor 1
   Pin A1 - input of feedback positioning from motor 2
   As well 5v and GND pins tapped in to feed feedback pots too.
#include <EEPROM.h>
//Some speed test switches for testers ;)
#define FASTADC  1 //Hack to speed up the arduino analogue read function, comment out with // to disable this hack
// defines for setting and clearing register bits
#ifndef cbi
   #define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
   #define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
#define LOWBYTE(v)   ((unsigned char) (v))                        //Read
#define HIGHBYTE(v)  ((unsigned char) (((unsigned int) (v)) >> 8))
#define BYTELOW(v)   (*(((unsigned char *) (&v) + 1)))               //Write
#define BYTEHIGH(v)  (*((unsigned char *) (&v)))
#define   GUARD_MOTOR_1_GAIN   100.0
#define   GUARD_MOTOR_2_GAIN   100.0
//Firmware version info
int firmaware_version_mayor=1;
int firmware_version_minor =4;
//360� option for flight simulators
bool turn360motor1 = false;
bool turn360motor2 = false;
int virtualtarget1;
int virtualtarget2;
int currentanalogue1 = 0;
int currentanalogue2 = 0;
int target1=512;
int target2=512;
int low=0;
int high=0;
unsigned long hhigh=0;
unsigned long hlow=0;
unsigned long lhigh=0;
unsigned long llow=0;
int buffer=0;
int buffercount=-1;
int commandbuffer[5]={0};
unsigned long pidcount   = 0;      // unsigned 32bit, 0 to 4,294,967,295
byte errorcount   = 0;      // serial receive error detected by checksum
// fixed DATA for direct port manipulation, exchange here each value if your h-Bridge is connected to another port pin
// This pinning overview is to avoid the slow pin switching of the arduino libraries
//            PC6  1|    |28  PC5 (AI 5)
//      (D 0) PD0  2|    |27  PC4 (AI 4)
//      (D 1) PD1  3|    |26  PC3 (AI 3)
//      (D 2) PD2  4|    |25  PC2 (AI 2)
// PWM+ (D 3) PD3  5|    |24  PC1 (AI 1)
//      (D 4) PD4  6|    |23  PC0 (AI 0)
//            VCC  7|    |22  GND
//            GND  8|    |21  AREF
//            PB6  9|    |20  AVCC
//            PB7 10|    |19  PB5 (D 13)
// PWM+ (D 5) PD5 11|    |18  PB4 (D 12)
// PWM+ (D 6) PD6 12|    |17  PB3 (D 11) PWM
//      (D 7) PD7 13|    |16  PB2 (D 10) PWM
//      (D 8) PB0 14|    |15  PB1 (D 9) PWM
int portdstatus            =PORTD;    // read the current port D bit mask
int ControlPinM1Inp1      =2;         // motor 1 INP1 output, this is the arduino pin description
int ControlPinM1Inp2      =3;         // motor 1 INP2 output, this is the arduino pin description
int ControlPinM2Inp1      =4;         // motor 2 INP1 output, this is the arduino pin description
int ControlPinM2Inp2      =5;         // motor 2 INP2 output, this is the arduino pin description
int PWMPinM1            =10;      // motor 1 PWM output
int PWMPinM2            =9;         // motor 2 PWM output
// Pot feedback inputs
int FeedbackPin1         = A0;      // select the input pin for the potentiometer 1, PC0
int FeedbackPin2         = A1;      // select the input pin for the potentiometer 2, PC1
int FeedbackMax1         = 1021;      // Maximum position of pot 1 to scale, do not use 1023 because it cannot control outside the pot range
int FeedbackMin1         = 2;      // Minimum position of pot 1 to scale, do not use 0 because it cannot control outside the pot range
int FeedbackMax2         = 1021;      // Maximum position of pot 2 to scale, do not use 1023 because it cannot control outside the pot range
int FeedbackMin2         = 2;      // Minimum position of pot 2 to scale, do not use 0 because it cannot control outside the pot range
int FeedbackPotDeadZone1   = 0;      // +/- of this value will not move the motor
int FeedbackPotDeadZone2   = 0;      // +/- of this value will not move the motor
float quarter1            = 254.75;
float quarter2            = 254.75;
float threequarter1         = 764.25;
float threequarter2         = 764.25;
//PID variables
int motordirection1      = 0;         // motor 1 move direction 0=brake, 1=forward, 2=reverse
int motordirection2      = 0;         // motor 2 move direction 0=brake, 1=forward, 2=reverse
int oldmotordirection1   = 0;
int oldmotordirection2   = 0;
double K_motor_1      = 1;
double proportional1   = 4.200;      //initial value
double integral1      = 0.400;
double derivative1      = 0.400;
double K_motor_2      = 1;
double proportional2   = 4.200;
double integral2      = 0.400;
double derivative2      = 0.400;
int OutputM1               = 0;
int OutputM2               = 0;
double integrated_motor_1_error = 0;
double integrated_motor_2_error = 0;
float last_motor_1_error      = 0;
float last_motor_2_error      = 0;
int disable                  = 1; //Motor stop flag
int pwm1offset               = 50;
int pwm2offset               = 50;
int pwm1maximum               = 255;
int pwm2maximum               = 255;
float pwm1divider            = 0.8039;
float pwm2divider            = 0.8039;
float pwmfloat               = 0;
int pwmfrequencydivider         = 1; //31kHz
byte debugbyte =0;            //This values are for debug purpose and can be send via
int debuginteger =0;         //the SendDebug serial 211 command to the X-Sim plugin
double debugdouble =0;
void setPwmFrequency(int pin, int divisor)
   byte mode;
   if(pin == 5 || pin == 6 || pin == 9 || pin == 10)
      switch(divisor)
         case 1: mode = 0x01; break;
         case 8: mode = 0x02; break;
         case 64: mode = 0x03; break;
         case 256: mode = 0x04; break;
         case 1024: mode = 0x05; break;
         default: return;
      if(pin == 5 || pin == 6)
         TCCR0B = TCCR0B & 0b11111000 | mode;
      else
         TCCR1B = TCCR1B & 0b11111000 | mode;
   else
      if(pin == 3 || pin == 11)
         switch(divisor)
            case 32: mode = 0x03; break;
            case 64: mode = 0x04; break;
            case 128: mode = 0x05; break;
            case 256: mode = 0x06; break;
            case 1024: mode = 0x7; break;
            default: return;
         TCCR2B = TCCR2B & 0b11111000 | mode;
void setup()
   //Serial.begin(115200);   //Uncomment this for arduino UNO without ftdi serial chip
   Serial.begin(9600);  //Uncomment this for arduino nano, arduino with ftdi chip or arduino duemilanove
   portdstatus=PORTD;
   pinMode(ControlPinM1Inp1, OUTPUT);
   pinMode(ControlPinM1Inp2, OUTPUT);
   pinMode(ControlPinM2Inp1, OUTPUT);
   pinMode(ControlPinM2Inp2, OUTPUT);
   pinMode(PWMPinM1,        OUTPUT);
   pinMode(PWMPinM2,        OUTPUT);
   analogWrite(PWMPinM1,     0);
   analogWrite(PWMPinM2,     0);
   UnsetMotor1Inp1();
   UnsetMotor1Inp2();
   UnsetMotor2Inp1();
   UnsetMotor2Inp2();
   disable=1;
   //TCCR1B = TCCR1B & 0b11111100; //This is a hack for changing the PWM frequency to a higher value, if removed it is 490Hz
   setPwmFrequency(9, 1);
   setPwmFrequency(10, 1);
#if FASTADC
   // set analogue prescale to 16
   sbi(ADCSRA,ADPS2) ;
   cbi(ADCSRA,ADPS1) ;
   cbi(ADCSRA,ADPS0) ;
#endif
void WriteEEPRomWord(int address, int intvalue)
   int low,high;
   high=intvalue/256;
   low=intvalue-(256*high);
   EEPROM.write(address,high);
   EEPROM.write(address+1,low);
int ReadEEPRomWord(int address)
   int low,high, returnvalue;
   high=EEPROM.read(address);
   low=EEPROM.read(address+1);
   returnvalue=(high*256)+low;
   return returnvalue;
void WriteEEProm()
   EEPROM.write(0,111);
   WriteEEPRomWord(1,FeedbackMin1);
   WriteEEPRomWord(3,FeedbackMax1);
   EEPROM.write(5,FeedbackPotDeadZone1);
   WriteEEPRomWord(6,FeedbackMin2);
   WriteEEPRomWord(8,FeedbackMax2);
   EEPROM.write(10,FeedbackPotDeadZone2);
   WriteEEPRomWord(11,int(proportional1*10.000));
   WriteEEPRomWord(13,int(integral1*10.000));
   WriteEEPRomWord(15,int(derivative1*10.000));
   WriteEEPRomWord(17,int(proportional2*10.000));
   WriteEEPRomWord(19,int(integral2*10.000));
   WriteEEPRomWord(21,int(derivative2*10.000));
   if(pwm1offset > 180 || pwm2offset > 180 || pwm1maximum < 200 || pwm2maximum < 200)
      pwm1offset=50;
      pwm2offset=50;
      pwm1maximum=255;
      pwm2maximum=255;
      pwm1divider=0.8039;
      pwm2divider=0.8039;
   EEPROM.write(23,pwm1offset);
   EEPROM.write(24,pwm2offset);
   EEPROM.write(25,pwm1maximum);
   EEPROM.write(26,pwm2maximum);
   if(pwmfrequencydivider != 1 && pwmfrequencydivider != 8)
      pwmfrequencydivider=1;
   EEPROM.write(27,pwmfrequencydivider);
void ReadEEProm()
   int evalue = EEPROM.read(0);
   if(evalue != 111) //EEProm was not set before, set default values
      WriteEEProm();
      return;
   FeedbackMin1=ReadEEPRomWord(1);
   FeedbackMax1=ReadEEPRomWord(3);
   FeedbackPotDeadZone1=EEPROM.read(5);
   FeedbackMin2=ReadEEPRomWord(6);
   FeedbackMax2=ReadEEPRomWord(8);
   FeedbackPotDeadZone2=EEPROM.read(10);
   proportional1=double(ReadEEPRomWord(11))/10.000;
   integral1=double(ReadEEPRomWord(13))/10.000;
   derivative1=double(ReadEEPRomWord(15))/10.000;
   proportional2=double(ReadEEPRomWord(17))/10.000;
   integral2=double(ReadEEPRomWord(19))/10.000;
   derivative2=double(ReadEEPRomWord(21))/10.000;
   pwm1offset=EEPROM.read(23);
   pwm2offset=EEPROM.read(24);
   pwm1maximum=EEPROM.read(25);
   pwm2maximum=EEPROM.read(26);
      pwm1offset=50;
      pwm2offset=50;
      pwm1maximum=255;
      pwm2maximum=255;
      pwm1divider=0.8039;
      pwm2divider=0.8039;
   else
      pwmfloat=float(pwm1maximum-pwm1offset);
      pwm1divider=pwmfloat/255.000;
      pwmfloat=float(pwm2maximum-pwm2offset);
      pwm2divider=pwmfloat/255.000;
   pwmfrequencydivider=EEPROM.read(27);
   quarter1=float(FeedbackMax1-FeedbackMin1)/4.000;
   quarter2=float(FeedbackMax2-FeedbackMin2)/4.000;
   threequarter1=quarter1*3.000;
   threequarter2=quarter1*3.000;
   setPwmFrequency(9, pwmfrequencydivider);
   setPwmFrequency(10, pwmfrequencydivider);
void SendAnalogueFeedback(int analogue1, int analogue2)
   high=analogue1/256;
   low=analogue1-(high*256);
   Serial.write('X');
   Serial.write(200);
   Serial.write(high);
   Serial.write(low);
   high=analogue2/256;
   low=analogue2-(high*256);
   Serial.write(high);
   Serial.write(low);
void SendPidCount()
   unsigned long value=pidcount;
   hhigh=value/16777216;
   value=value-(hhigh*16777216);
   hlow=value/65536;
   value=value-(hlow*65536);
   lhigh=value/256;
   llow=value-(lhigh*256);
   Serial.write('X');
   Serial.write(201);
   Serial.write(int(hhigh));
   Serial.write(int(hlow));
   Serial.write(int(lhigh));
   Serial.write(int(llow));
   Serial.write(errorcount);
void SendDebugValues()
   //The double is transformed into a integer * 10 !!!
   int doubletransfere=int(double(debugdouble*10.000));
   Serial.write('X');
   Serial.write(211);
   Serial.write(debugbyte);
   Serial.write(HIGHBYTE(debuginteger));
   Serial.write(LOWBYTE(debuginteger));
   Serial.write(HIGHBYTE(doubletransfere));
   Serial.write(LOWBYTE(doubletransfere));
void SendFirmwareVersion()
   Serial.write('X');
   Serial.write('-');
   Serial.write('P');
   Serial.write('I');
   Serial.write('D');
   Serial.write(' ');
   Serial.write(48+firmaware_version_mayor);
   Serial.write('.');
   Serial.write(48+firmware_version_minor);
void EEPromToSerial(int eeprom_address)
   int retvalue=EEPROM.read(eeprom_address);
   Serial.write('X');
   Serial.write(204);
   Serial.write(retvalue);
void ClearEEProm()
   for(int z=0; z < 1024; z++)
      EEPROM.write(z,255);
void ParseCommand()
   if(commandbuffer[0]==1)         //Set motor 1 position to High and Low value 0 to 1023
      target1=(commandbuffer[1]*256)+commandbuffer[2];
      disable=0;
      return;
   if(commandbuffer[0]==2)         //Set motor 2 position to High and Low value 0 to 1023
      target2=(commandbuffer[1]*256)+commandbuffer[2];
      disable=0;
      return;
   if(commandbuffer[0]==200)      //Send both analogue feedback raw values
      SendAnalogueFeedback(currentanalogue1, currentanalogue2);
      return;
   if(commandbuffer[0]==201)      //Send PID count
      SendPidCount();
      return;
   if(commandbuffer[0]==202)      //Send Firmware Version
      SendFirmwareVersion();
      return;
   if(commandbuffer[0]==203)      //Write EEPROM
      EEPROM.write(commandbuffer[1],uint8_t(commandbuffer[2]));
      return;
   if(commandbuffer[0]==204)      //Read EEPROM
      EEPromToSerial(commandbuffer[1]);
      return;
   if(commandbuffer[0]==205)      //Clear EEPROM
      ClearEEProm();
      return;
   if(commandbuffer[0]==206)      //Reread the whole EEPRom and store settings into fitting variables
      ReadEEProm();
      return;
   if(commandbuffer[0]==207 || commandbuffer[0]==208)      //Disable power on both motor
      UnsetMotor1Inp1();
      UnsetMotor1Inp2();
      UnsetMotor2Inp1();
      UnsetMotor2Inp2();
      disable=1;
      return;
   if(commandbuffer[0]==209 || commandbuffer[0]==210)      //Enable power on both motor
      analogWrite(PWMPinM1,     128);
      UnsetMotor1Inp1();
      UnsetMotor1Inp2();
      analogWrite(PWMPinM2,     128);
      UnsetMotor2Inp1();
      UnsetMotor2Inp2();
      disable=0;
      return;
   if(commandbuffer[0]==211)      //Send all debug values
      SendDebugValues();
      return;
void FeedbackPotWorker()
   currentanalogue1 = analogRead(FeedbackPin1);
   currentanalogue2 = analogRead(FeedbackPin2);
   //Notice: Minimum and maximum scaling calculation is done in the PC plugin with faster float support
bool CheckChecksum() //Atmel chips have a comport error rate of 2%, so we need here a checksum
   byte checksum=0;
   for(int z=0; z < 3; z++)
      byte val=commandbuffer[z];
      checksum ^= val;
   if(checksum==commandbuffer[3]){return true;}
   return false;
void SerialWorker()
   while(Serial.available())
      if(buffercount==-1)
         buffer = Serial.read();
         if(buffer != 'X'){buffercount=-1;}else{buffercount=0;}
      else
         commandbuffer[buffercount]=buffer;
         buffercount++;
         if(buffercount > 3)
            if(CheckChecksum()==true){ParseCommand();}else{errorcount++;}
            buffercount=-1;
void CalculateVirtualTarget()
   if(turn360motor1==true)
      virtualtarget1=target1;
      if(currentanalogue1 > int(threequarter1) && target1 < int(quarter1)){virtualtarget1+=FeedbackMax1;}
      else{if(currentanalogue1 < int(quarter1) && target1 > int(threequarter1)){virtualtarget1=0-FeedbackMax1-target1;}}
   else
   if(turn360motor2==true)
      virtualtarget2=target2;
      if(currentanalogue2 > int(threequarter2) && target2 < int(quarter2)){virtualtarget2+=FeedbackMax2;}
      else{if(currentanalogue2 < int(quarter2) && target2 > int(threequarter2)){virtualtarget2=0-FeedbackMax2-target2;}}
   else
void CalculateMotorDirection()
   if(virtualtarget1 > (currentanalogue1 + FeedbackPotDeadZone1) || virtualtarget1 < (currentanalogue1 - FeedbackPotDeadZone1))
      if (OutputM1 >= 0)
         motordirection1=1;            // drive motor 1 forward
      else
         motordirection1=2;            // drive motor 1 backward
         OutputM1 = abs(OutputM1);
   else
      motordirection1=0;
   if(virtualtarget2 > (currentanalogue2 + FeedbackPotDeadZone2) || virtualtarget2 < (currentanalogue2 - FeedbackPotDeadZone2))
      if (OutputM2 >= 0)
         motordirection2=1;            // drive motor 2 forward
      else
         motordirection2=2;            // drive motor 2 backward
         OutputM2 = abs(OutputM2);
   else
      motordirection2=0;
   OutputM1 = constrain(OutputM1, -255, 255);
   OutputM2 = constrain(OutputM2, -255, 255);
int updateMotor1Pid(int targetPosition, int currentPosition)
   float error = (float)targetPosition - (float)currentPosition;
   float pTerm_motor_R = proportional1 * error;
   integrated_motor_1_error += error;
   float iTerm_motor_R = integral1 * constrain(integrated_motor_1_error, -GUARD_MOTOR_1_GAIN, GUARD_MOTOR_1_GAIN);
   float dTerm_motor_R = derivative1 * (error - last_motor_1_error);
   last_motor_1_error = error;
   return constrain(K_motor_1*(pTerm_motor_R + iTerm_motor_R + dTerm_motor_R), -255, 255);
int updateMotor2Pid(int targetPosition, int currentPosition)
   float pTerm_motor_L = proportional2 * error;
   integrated_motor_2_error += error;
   float iTerm_motor_L = integral2 * constrain(integrated_motor_2_error, -GUARD_MOTOR_2_GAIN, GUARD_MOTOR_2_GAIN);
   float dTerm_motor_L = derivative2 * (error - last_motor_2_error);
   last_motor_2_error = error;
   return constrain(K_motor_2*(pTerm_motor_L + iTerm_motor_L + dTerm_motor_L), -255, 255);
void CalculatePID()
   OutputM1=updateMotor1Pid(virtualtarget1,currentanalogue1);
   OutputM2=updateMotor2Pid(virtualtarget2,currentanalogue2);
void SetPWM()
   //Calculate pwm offset and maximum
   pwmfloat=OutputM1;
   pwmfloat*=pwm1divider;
   pwmfloat+=float(pwm1offset);
   OutputM1=pwmfloat;
   if(OutputM1 > pwm1maximum){OutputM1=pwm1maximum;}
   pwmfloat=OutputM2;
   pwmfloat*=pwm2divider;
   pwmfloat+=float(pwm2offset);
   OutputM2=pwmfloat;
   if(OutputM2 > pwm2maximum){OutputM2=pwm2maximum;}
   //Set hardware pwm
   if(motordirection1 != 0)
      analogWrite(PWMPinM1, int(OutputM1));
   else
   if(motordirection2 != 0)
      analogWrite(PWMPinM2, int(OutputM2));
   else
//Direct port manipulation, change here your port code
void SetMotor1Inp1()
   portdstatus |= 1 << ControlPinM1Inp1;
   PORTD = portdstatus;
void UnsetMotor1Inp1()
   portdstatus &= ~(1 << ControlPinM1Inp1);
void SetMotor1Inp2()
   portdstatus |= 1 << ControlPinM1Inp2;
void UnsetMotor1Inp2()
   portdstatus &= ~(1 << ControlPinM1Inp2);
void SetMotor2Inp1()
   portdstatus |= 1 << ControlPinM2Inp1;
void UnsetMotor2Inp1()
   portdstatus &= ~(1 << ControlPinM2Inp1);
void SetMotor2Inp2()
   portdstatus |= 1 << ControlPinM2Inp2;
void UnsetMotor2Inp2()
   portdstatus &= ~(1 << ControlPinM2Inp2);
void SetHBridgeControl() //With direct port manipulation for speedup the arduino framework!
   //Motor 1
   if(motordirection1 != oldmotordirection1)
         if(motordirection1 == 1)
            SetMotor1Inp1();
            UnsetMotor1Inp2();
         else
            UnsetMotor1Inp1();
            SetMotor1Inp2();
      else
         UnsetMotor1Inp1();
         UnsetMotor1Inp2();
      oldmotordirection1=motordirection1;
   //Motor 2
   if(motordirection2 != oldmotordirection2)
         if(motordirection2 == 1)
            SetMotor2Inp1();
            UnsetMotor2Inp2();
         else
            UnsetMotor2Inp1();
            SetMotor2Inp2();
      else
         UnsetMotor2Inp1();
         UnsetMotor2Inp2();
      oldmotordirection2=motordirection2;
void loop()
   //Read all stored PID and Feedback settings
   ReadEEProm();
   //Program loop
   while (1==1) //Important hack: Use this own real time loop code without arduino framework delays
      FeedbackPotWorker();
      SerialWorker();
      CalculateVirtualTarget();
      CalculatePID();
      CalculateMotorDirection();
      if(disable==0)
         SetPWM();
         SetHBridgeControl();
      pidcount++;
Y no pasa nada, nunca se mueven los motores, adjunto imágenes de mi configuración y de las conexiones, de las cuales no tengo duda. pero por las dudas.
Espero me puedan ayudar.
wallytattoo
Has thanked: 5 times
Postby mosky2014 » Thu 31. Jul 2014, 09:33
dualin wrote:La verdad es que esos baquets son interesantes. Los estuve viendo ayer y si que es cierto que comprando dos y repartiendo es súper interesante. Yo acabare comprando uno, pero ahora no tengo pasta, además en ese que ha puesto no cabe mi culo, jeje, yo necesito un semibaquet
Saludos
Dualin
Ahora esto leyendo bien, veo que dicen que para pedidos mayores de 299 euros envíos gratis
"ENVÍO GRATIS A PARTIR DE UNA COMPRA DE 299,00€
(solo disponible si realiza su pedido por internet)"
Vamos gente tenemos que poder juntar algunos para aprovechar dejo las fotos
Estos negros y naranjas por 129,90 euros
estos negros por 116,80
Estos grises 86,20
Yo esto a punto de pedir los Negros y Naranjas ya veré que hago con el que me sobre.
Vamosssssssssssssssssss :roll:
Dualin ponete las pilas y baja unos kilos para la operación bikini y compramos el Naranja y Negro ( o yo los compro y como premio a la dukan te los regalas tú)
Un saludo
mosky2014
Postby profetadelmus » Thu 31. Jul 2014, 10:07
wallytatoo, varias cosas:
1.- Lo primero de todo es comprobar que en el Interface Settings, si poniendo valores porcentuales en el cuadrado de "test one interface output pin", los motores van al sitio que le pides: si pones un 0 o le das a clear output, el motor seleccionado tiene que mover la biela al minimo, si le pones un 50% a la mitad, al 100% arriba de todo, etc... Si eso lo hace, vas por buen camino. Creo que te falta ajustar tambien los máximos y minimos de la biela porque en la configuración (pantalla 5) tienes el minimo en 0 y el máximo en 1021 (pero eso depende de como hayas montado el tinglado)
2.- Si utizas X-PID, no vas a usar USO, asi que en el apartado de USO (pantalla 2), quita todo lo relativo al COM5.
3.- En la pantalla 3, en donde pone "Control output of axis", pones "Axis 1 Der", pero te falta seleccionar mas abajo en donde pone "output axis direct" la salida de tu X-PID (ahora lo tienes en "Do not use a direct output"). Ahí para Axis 1 Der deberías de marcar X-PID 1.4 COM5 Position 1 y para el Axis 1 Izq, el X-PID 1.4 COM5 Position 2.
A ver si te ayuda!!!
profetadelmus
Images: 32
Has thanked: 10 times
Postby nachomdq » Thu 31. Jul 2014, 16:06
Mosky,
Veo que estas buscando butacas, te cuento que yo conseguí una de regalo, el tema es así aqui en Argentina hay muchas categorias de automovilismo y las butacas de los autos de competición tienen vencimiento, la que me regalaron es una vencida que no sirve para un auto de competición pero sirve perfectamente para nuestro simulador, te cuento esto porque a lo mejor allí en España podes llegar a conocer algún team racing y preguntar como hice yo y seguramente tienen algunas que no usen.
Saludos
Nacho
nachomdq
Postby profetadelmus » Thu 31. Jul 2014, 16:20
Saludos
Dualin
El problema del semibaquet es que pesan bastante más que un baquet.
A los q estáis buscando, echad un vistazo en mercadoracing.org que de segunda mano podéis conseguir algún baquet caducado como dice el compañero anterior
profetadelmus
Images: 32
Postby mosky2014 » Thu 31. Jul 2014, 17:14
nachomdq wrote:Mosky,
Saludos
Nacho
Gracias Nacho, me voy a fijar si encuentro algo por ese lado
Un saludo
mosky2014
Postby mosky2014 » Thu 31. Jul 2014, 17:15
Saludos
Dualin
Gracias por el enlace voy a buscar ahí
Un saludo
mosky2014
Postby PSArias » Thu 31. Jul 2014, 18:07
Buenas compañeros! No es por molestar.. Pero no sería mejor abrir un hilo específico para lo de los baquets? De esa manera queda todo mucho más ordenado y si hay alguien interesado lo podrá encontrar mejor que en una de las tantas páginas de este hilo.
Nos sirve a nosotros y a los que vengan en un futuro... Intentemos mantener los temas en sus hilos, veréis como al final se agradece ;)
EDITO: El hilo ya lo he creado, lo tenéis aquí: viewtopic.php?f=67&t=1562
Saludos!
PSArias
Postby mosky2014 » Thu 31. Jul 2014, 18:11
PSArias wrote:Buenas compañeros! No es por molestar.. Pero no sería mejor abrir un hilo específico para lo de los baquets? De esa manera queda todo mucho más ordenado y si hay alguien interesado lo podrá encontrar mejor que en una de las tantas páginas de este hilo.
Saludos!
Ok, si me parece bien. En cuanto me entere como crear un hilo, y lo pueda mover lo hago. Lo siento me deje llevar por la euforia :roll:
Gracias
mosky2014
Postby wallytattoo » Fri 1. Aug 2014, 05:04
Gracias profetadelmus, se empezó a mover, tenía problema porque estaba probando con la alimentación directamente del usb. ahora le agregué una fuente externa y se empezaron a mover, pero igual vibran mucho. así que estoy variando los valores del pid.
También corregí lo que me pones en los puntos para ver.Quiero aclara que lo estoy haciendo en miniatura, hata que funcione bien y me llegen algunas placa como la monster .
Gracias por la ayuda brindada hasta ahora, les iré comentando los avances. saludos
wallytattoo
