2DOF SFGT with AMC 1.6 and DSHb 1.2b configuration
Postby TheXRacer » Sat 25. May 2013, 12:41
Hi all,
In recent days I put my 2DOF Sim and my harware done. :D
The simulator is built with two wiper motors as SFGT ....
Now I need some help how I can configure my Sim to Sim X, there is possibly an instruction under a tutorial?
Hardware: 10KOhm pot, Thanos AMC 1.6 + 1.2b DSHB and two Wipermotors wit 12V/45Watts
If someone could help me I would be very grateful! :P
best regards
Christian
TheXRacer
Images: 9
Has thanked: 5 times
Re: 2DOF SFGT with AMC 1.6 and DSHb 1.2b configuration
Postby TheXRacer » Sat 25. May 2013, 15:20
I need a little bit help for my small Prob. ! :)
regards
Chris
TheXRacer
Images: 9
Postby TheXRacer » Sat 25. May 2013, 18:09
Hey i found anything tutorial on the forum i need help ....... :roll:
TheXRacer
Images: 9
Postby vicpopo » Sat 25. May 2013, 20:00
Please some pictures and more details from what you want to begin !
Postby sirnoname » Sat 25. May 2013, 20:08
There is a traning tutorial which explains step by step the first contact.
The difference between the 3D simulation and your hardware is a small output string in the Universal Serial Output. You give there a comport and a string for the AMC. I cannot figure out where you have missing parts!
ps. you can also switch to the german subforum if you like ;)
Postby TheXRacer » Sat 25. May 2013, 21:00
hallo sirnoname,
ich habe soweit die USO´s verstanden, kann auch meine math settings konfigurieren, problem ist jetzt nur wie ich den max/min Weg der Potentiometer bestimmen kann ?
Ist mir noch etwas unschlüssig, wie muss ich vorgehen Schritt für Schritt erklärung wäre hilfreich !
Oder was sasgst Du/Ihr ?
Ist eig. das einzigste was ich noch nicht so richtig verstehe .
Hardware war: AMC 1.6 v1.1h am wipersim in SFGT Art
grüße
Christian
TheXRacer
Images: 9
Postby sirnoname » Sat 25. May 2013, 22:48
Da solltest du dich in den open source arduino interface Bereich begeben. Dort steht wie man mit einem Poti verfährt. Alle min/max Werte beschränken die anfahrbaren Positionen.
Wenn ich es richtig verstehe, dann suchst du für das AMC eine Bedienungsanleitung zum Einstellen der Potis?
Postby TheXRacer » Sat 25. May 2013, 22:54
genau Du sagst es ich benötige eine Anleitung wie ich die Verfahrwege der Potentiometer über X-Sim einstellen kann.
Gruß
Christian
TheXRacer
Images: 9
Postby sirnoname » Sat 25. May 2013, 23:12
Ich frag ihn mal wo das steht, das meiste ist ja über Hall Effekt potis gelösst.
Auf die Schnelle kannst du ja mal die Alternative Firmware probieren:
viewtopic.php?f=39&t=237&hilit=pdf
Da ist ein Manual dabei.
Ich schiebe dich ins deutsche Forum ...
Postby TheXRacer » Sat 25. May 2013, 23:47
dank Dir sehr , wird mal versuchen ob ich mit deiner vorgeschlagenen Alternativsoftware zurecht komme !
Also danke nochmal für deine Hilfe !!! :)
Beste Grüße
Christian
TheXRacer
Images: 9
