power for mini 6dof
Topics and questions about power supplies
power for mini 6dof
Postby Aahmed » Sun 24. May 2015, 03:37
Hi
i am building mini 6dof platform using the following :
amc1280usb
1x Pololu Micro Serial Servo Controller
6 X standard servo motor
and I didn't find any thing about power source for mini servo motor , maybe this self-evident for every one here but i have no background/ experiences with this
should i use normal power adapter (5v) and connect it to polou controller ? can i you phone charger ? what about AMP ?
or connect power source to amc1280 ?
any information or link that can help is much appreciated
thank you
Aahmed
Re: power for mini 6dof
Postby adrianovrm » Sun 24. May 2015, 05:27
L dos mine , l use 3 unities of 5 volts per 3 amperes , use powwer unit feeds 2 servos futaba mg995, l out a Capacitor 3300 uf /per 24 volts at each power unit ,if you try ti use just one power unit for all motor , the will Get craY cause oscillations voltagem leve ll
adrianovrm
Postby Aahmed » Mon 25. May 2015, 23:32
adrianovrm wrote:L dos mine , l use 3 unities of 5 volts per 3 amperes , use powwer unit feeds 2 servos futaba mg995, l out a Capacitor 3300 uf /per 24 volts at each power unit ,if you try ti use just one power unit for all motor , the will Get craY cause oscillations voltagem leve ll
thank you for your help . but i am not sure that i know what i need to use in my case
servos i used : HS-311 (6x) and they already connected to (Pololu Micro Serial Servo Controller ) should i use power adapter and connect it to the controller or
connect adapter to amc1280usb ?
and what adapter should i use ? ( how many volt and amp)
thank you
Aahmed
Postby tronicgr » Tue 26. May 2015, 01:52
You will need a small PSU 5-6volts and 1.5 - 2.5 ampere.
Don't go over 6volts as you might damage the electronics in the servo motors.
See how you connect everything here: http://motionsim.freeforums.net/thread/7/faq-rc-servos
You don't need to connect power to the AMC1280USB, just the USB cable. The power for the mini servos is connected on the pololu mini servo controller.
Postby Aahmed » Mon 8. Jun 2015, 01:44
thank you tronicgr , thats very hlpful
it's working now :)
Aahmed
Return to Power supplies
