What is FFB and how do I get it?
Postby mykodacon » Fri 13. Apr 2012, 19:47
Hello,
When I click MotionDriver, and on the left side there is a ForceFeedback option. When I click it and try to enable it, it says it is not supported for stage 1 and to come to this site to learn how to get it for free.
1st question: What does it do? Does it add more FFB to the steering wheel for wheels that already use FFB?
2nd question: How do I get it?
Thank you
Mike
mykodacon
Re: What is FFB and how do I get it?
Postby sirnoname » Fri 13. Apr 2012, 20:25
Read the download tab or the left menues on the homepage entry "Terms of usage". For both questions.
Postby mykodacon » Fri 13. Apr 2012, 21:50
I am not a programmer, so I am unable to do any of the things requires to get ffb, but I would be willing to give a donation for it. How much should I donate to get to use it and where should I send it?
mykodacon
Postby sirnoname » Fri 13. Apr 2012, 23:43
There is no need to be a programmer, you only must fill out the project pages here like the others did.
Postby RichP » Wed 20. Feb 2013, 17:17
Hi All, i am struggling to find the "terms of usage" i ca only see "terns of forum use"
FYI i am trying to access FFB section for which i need a stage 2 key
Thanks all
Rich
RichP
Postby sirnoname » Wed 20. Feb 2013, 17:41
This is nothing for you.
The ff driver will scan an existing ff wheel and double the set of mixed instructions to the X-Sim software. There you can select i.e. the lateral force for simulator movement. It is not a ff joystick driver. You have to make a closer look for a reused electronic of a wheel or the imersion development board.
Return to Forum & Website
