Problems with 4K and Windows 10
Postby goskar » Tue 27. Mar 2018, 13:31
Hi all,
I have a little problem with the interface of the x-sim.
First of all, when I turn on the Windows on a 4K TV and I run both X-SIM extractor & converter I find that the menus get spoiled: I am not able to open all the buttons and the interface blinks (I will share some screeshots later). If I change the resolution to 1080p, the problem persists BUT if I turn on the PC on a 1080P TV, eventhough I switch back the resolution to 4k.
Does anybody know a trick of how to fix this problem?
Kind regards,
Goskar.
goskar
Re: Problems with 4K and Windows 10
Postby andrea1979 » Sat 6. Nov 2021, 21:33
Anch'io ho lo stesso problema . Come posso risolvere? Mi potete aiutare?
Grazie
andrea1979
Postby sirnoname » Sun 7. Nov 2021, 14:32
If you use 4k, you may need to switch to 100% zoom in windows display settings.
Return to Forum & Website
