New user logging in problems
Postby Dazbolt » Fri 13. Nov 2015, 20:42
This is probably easily sorted as I'm new fairly to pc's. I've downloaded the x-sim software and the extractor patch but still have problems logging in, I'm using Windows 10. It may be that I'm doing something wrong with the patch but I've now tried numerous times. If someone can point me in the right direction I'd be very grateful.
Dazbolt
Re: New user logging in problems
Postby sirnoname » Sat 14. Nov 2015, 11:31
what shows the bottom line? and how often you have problems? did you remove the windows patch?
Postby Dazbolt » Sat 14. Nov 2015, 13:48
I've had the problem every time I've tried to log in. The bottom line says logging out old user then logging in new user then after 5 seconds it just goes back to the log n screen. I've tried it first without the patch then with, without the patch it doesn't even try to log in
Dazbolt
Postby sirnoname » Sat 14. Nov 2015, 15:00
it seems you use an old/wrong login/password combination if it goes back to login screen. Use the X-Sim registry cleaner and try again.
Also do not use special characters for password as written in the registration form.
Additionally you did not answer the part of the windows patch as written here and in the patch DL section.
Postby Dazbolt » Sat 14. Nov 2015, 16:11
Thanks for the reply, I assumed it was the loggin and password for the forum which works fine. Do you mean remove the flash player update? If so I have no idea how to do that as I don't want to affect anything else.
Dazbolt
Return to Forum & Website
