connection 2 pc w8.1 and win732
Postby kermit » Tue 1. Sep 2015, 12:38
I have a probleem with aluminium 3.0
I have a pc win8.1 64 bit(main Game PC+ extractor ) and 1 pc win7 32 (for instruments , and X sim),
treid to connect them with lan cable , have uac disabled and admin rigths on both pcs,
using Fsuipc Payware ,
when start x sim on Game pc I need to connect with my name and password , on the second pc I start the other , but can`t see connection
on the game pc I see Lokal connection?
All firewalls and virusscanners are disabled
greetz
kermit
Re: connection 2 pc w8.1 and win732
Postby sirnoname » Tue 1. Sep 2015, 18:55
There is another plugin in work without FSUIPC, smoother and faster.
For your connection problems - in the newest edition there are many problems solved and there is a auto find feature. So if they do not find each other you have IP range problems or a good firewall.
Postby kermit » Wed 2. Sep 2015, 12:20
HI ,
Thanks for you answer, I have turned the firewall from the both computer off,
but no luck, what do you mean with Ip range?
regards Henk
kermit
Return to Forum & Website
