Windows 10 compatibility: ok
Postby Mertensbart20 » Fri 7. Aug 2015, 18:52
Hello everybody,
Just wanted to let you know that I got my simulator working with X-sim and Windows 10.
Greetings,
Bart
Mertensbart20
Re: Windows 10 compatibility: ok
Postby nosimula » Sat 8. Aug 2015, 17:48
Hello Bart.
I have a motion sim done with the Velleman k855. My converter is not working. When I go to load the profile he simply hangs and stops working. The extractor is working in a good, convert lock. Recalling that both are being started as administrator. On my Windows 10 does not. Can you help me?
nosimula
Postby Mertensbart20 » Tue 11. Aug 2015, 08:38
I suppose you installed the latest X-sim version.
And did the k855 driver install properly? To install the driver for the VM140 I had to do this:
https://www.youtube.com/watch?v=StkR3D2d5WI
Mertensbart20
Postby jorgebarrosc » Thu 27. Aug 2015, 20:17
Tested on windows 10 too, it works without problems.
jorgebarrosc
Postby lucisdisozx » Fri 20. Nov 2015, 10:58
I like this site But a good book to read as well
lucisdisozx
Return to Forum & Website
