rear traction loss project info
Postby abs2 » Fri 18. Apr 2014, 16:30
hello, I am comtemplating to upgrade my diy 2 dof for a rear traction loss
i d like some info . should the motion be left and right as a tranversal motion or rotational with a pivot in the front.
i am thinking of a system of bearing in the front and in the back to move my aluminum frame (45x45 mm)
if both are ok which is better and more realistic?
i also cant find any tutorial drawings in x-sim where as 4 years ago it was easy to find
also: what kind of lateral motion (in length) is realistic (5 cm, 10 cm ?). is snc5 100 mm ok ?
i use 2 snc5 150 for regular motion behind the seat, can i use snc5 100 mm for rear traction loss or must i use 150 mm actuator.
also : pivot (rotational) or ful lateral motion ? is there a difference in feeling?
thank you guys , hope to get few answer
abs2
Re: rear traction loss project info
Postby RacingMat » Wed 23. Apr 2014, 12:05
Hi abs2!
I think that pivot solution is much cheaper and mechanically simplier.
Tranversal motion is possible as well but what I have seen is slower setup than pivot's...
And I believe that pivot solution is more suitable with fixed screens.
You can find useful and detailed information on yokoyoko's post viewtopic.php?f=37&t=289
yours
Mat
Return to Forum & Website
