2DOF racesimulator for sale/free
Postby Mertensbart20 » Tue 23. Jul 2013, 11:02
Hello everybody,
My name is Mertens Bart and I live in Belgium, Limburg. Two years ago I started a schoolproject which I financed myself to build a 2DOF-racesimulator based on the design of Thanos. This simulator can be seen in action here:
https://www.youtube.com/watch?v=q6HtIFWxAf4
Last year we build a new simulator according to the thruxim-design (you can see it in this forum):
viewtopic.php?f=37&t=335
And this simulator will be expanded with a third dimension (yaw) this schoolyear. But this expansion also means I won't have enough room in my basement for both simulator so the old one will have to go.
Since I am a true open source guy this simulator is partly free :-) . The only items that are not free are the ones that I will reuse and these are the motorcontroller (a Sabertooth2x25), the controller (an arduino due and Velleman VM140), the supply (a 24V 10A supply) , the monitor and the steering wheel. Prices are negotiable or you can leave these items and take the rest for free.
Keep in mind that the simulator will have to partially be disassembled since the simulator can't fit in one piece through the door. And ofcourse I can help you online should you have questions restarting the simulator.
Should anybody be interested, let me * The simulator will have to go by the end of june 2014 and it would be a shame if it would be totally disassembled and thrown away.
Greetings,
Bart
Mertensbart20
Re: 2DOF racesimulator for sale/free
Postby kermit » Thu 21. Nov 2013, 14:17
Hi Bart, Do you have de VM 140 still for sale,
I`m very interested (for VM 140 only)
Please can you send me a Quote for this shipping to The netherlands
zipp code 2324 CS
hjanssen1069(at)casema.nl
regards Henk
kermit
Postby Mertensbart20 » Thu 21. Nov 2013, 20:51
Hallo Henk,
De Vellemankit kost nieuw bij Conrad 135 euro. Voor 62,5 euro kan je hem hebben. Wil je ook een voeding, die krijg je er bij voor 5 euro.
Als dat voor jouw goed is zal ik eens kijken wat de verzending kost.
Laat maar weten,
Bart
Mertensbart20
Postby kermit » Thu 21. Nov 2013, 23:41
Goedeavond Bart , Ik heb interesse incl voeding ,
welke potmeters gebruik je hiervoor ,ik zie verschillende platforms met de VM 140 ,
maar kom er niet uit of ook de snelheid geregeld wordt met dit boardje,
Ik wil deze gebruiken met 2 freqentie omvormers en 2 3ph 550 motoren
mijn 1.6 amc board heeft behoorlijk last van interference ,hierdoor bewegen de motoren klein stukje heen en weer zonder stil te staan heeft dit boardje
er ook last van ?
groet Henk
kermit
Postby Mertensbart20 » Fri 22. Nov 2013, 00:19
Hallo Henk,
Ik gebruik de VM140 enkel als omzetter van de digitale X-sim data naar analoge spanningen van 0 tot 10V. Ik laat de VM140 dus geen rekenwerk doen want dat bordje is niet erg snel. De verwerking van de analoge signalen van de VM140 wordt gedaan door een PLC die vervolgens frequentieomvormers aanstuurt. Eventueel kan je de aankoop van een simpele beckhoff-plc overwegen. Daar kan ik je dan ook de programma's voor geven. Persoonlijk ben ik ook niet voor potentiometers voor positiebepaling, die zijn niet accuraat en zeer slijtage gevoelig. ik gebruik liever encoders
Concreet om je vraag te beantwoorden, daar ik de VM140 heel anders gebruik kan ik je vraag niet beantwoorden. Wel kan ik je aan oplossing aanbieden via een PLC.
Groeten,
Bart
Mertensbart20
Postby kermit » Fri 22. Nov 2013, 00:49
Hallo Bart,
Ik heb frequentie omvormers Bonfiglioli Synplus( www. b o n f i g l i o l i . c o m) met een simpel plc functie en ladderprogramma,
maar mijn kennis is te weinig om hier iets mee te kunnen.
Hoe wil je dit verder afhandelen?
gr Henk
kermit
Postby Mertensbart20 » Fri 22. Nov 2013, 08:11
Van daaruit kan ik je wel heen loodsen, zo moeilijk is het niet. Wat voor PLC is het en wat zijn de in en uitgangen?
Mertensbart20
Postby kermit » Fri 22. Nov 2013, 10:04
Hoi Bart,
stuur mij een pm met uw emailadres dan kan ik de handleiding toe sturen ,
maar het is een ingebouwde plc en PID besturing
gr henk
Ps kan ik het bordje via pay[pal betalen?
Henk
kermit
Postby Mertensbart20 » Fri 22. Nov 2013, 19:22
Hallo Henk,
De verzendkosten zouden 12,90 euro bedragen. Samen met de VM140 en de voeding komt het op 80,4 euro (=62.5+5+12.9). Is dat ok voor jou?
Als je mij je emailadres doorstuurt waar je paypal aan gelinkt is dan stuur ik een betaalverzoek.
Groeten,
Bart
Mertensbart20
Postby kermit » Fri 22. Nov 2013, 21:35
At natuurlijk vervangen met @
zitten er ook de witte connectoren bij voor de digitale en analoge aansluitingen,
stuur mij uw emailadres voor de handleiding van de omvormers
gr Henk
kermit
Return to Forum & Website
