[Fixed] Safari browser problems
Report bugs regarding the forum & website (this forum is closed! please use the bugtracker instead)
Postby eldeejay » Wed 1. Aug 2012, 09:02
Good morning, I wanted to report that with the browser "Safari" from Apple, the forum does not work correctly. Details I've seen so far:
- The user panel is not displayed.
- The pictures published in the post are not displayed, and you see the warning "do not have permission to access files released"
- When you login, the forum reports that "the login is successful" but I get the impression that you're not really loged.
I have checked this problem using Mozilla Firefox and I.Explorer in both browsers run all ok.
regards
eldeejay
Images: 6
Re: [Pending] Safari browser problems
Postby floriske » Wed 1. Aug 2012, 10:16
I won't have access to a system with safari before monday, I'll see if I can reproduce the problem than.
In the meantime I hope you won't mind using Firefox (which is a better browser anyway ;))
floriske
Images: 96
Postby eldeejay » Wed 1. Aug 2012, 10:26
Hello Mr. Floriske, no problem I use firefox too hehehe, my intention is to help with the positive development of this new forum.
The problem occurs in Safari using Apple computers. I have reviewed this problem using Safari for PC and everything works perfectly.
Regardssss
eldeejay
Images: 6
Postby floriske » Mon 6. Aug 2012, 11:41
I was able to reproduce this problem and it's due to the message posted on the portal
Due to some updates it might be possible that you experience problems loging in. If this problem occurs please clear all browser cookies: http://www.wikihow.com/Clear-Your-Browser%27s-Cookies this should fix the problem.
In my case in Safari this required three steps:
• Go to the "History" tab and clear the history
• Go to the "Safari" tab and empty the cache
• Go to the "Safari" tab -> "Preferences" -> "Privacy" and remove all website data.
That did the trick for me, please let me know if it works for you as well.
Edit: another solution might be to clear all cookies through the user control panel (on the right in the bottom grey bar): ucp.php?mode=delete_cookies
floriske
Images: 96
Postby eldeejay » Tue 7. Aug 2012, 13:03
Mr. Floriske good morning, I made ​​the steps detailed and resolved properly.
Regards
eldeejay
Images: 6
Postby floriske » Tue 7. Aug 2012, 13:52
Thanks for your confirmation!
floriske
Images: 96
Return to Report a bug
