New Windows 10 update breaks Extractor
Report bugs regarding the forum & website (this forum is closed! please use the bugtracker instead)
Postby mreiner » Sat 2. Jan 2016, 13:49
Hi A recently released update for Windows 10 is crashing the Extractor on start. (Extractor.exe has stopped working).
The update is this one:
https://support.microsoft.com/en-us/kb/3132372
I've deinstalled it, and now Extractor is working again.
kr Martin
mreiner
Images: 22
Been thanked: 15 times
Re: New Windows 10 update breaks Extractor
Postby sirnoname » Sat 2. Jan 2016, 14:56
Bad news, the last flash Update did same strange things.
I will have a look to it in about a week, for now you need to uninstall this plugin if possible in W10.
Postby sirnoname » Sat 9. Jan 2016, 12:54
Updated to Win 10 but all is working perfect. No crash.
Postby asticher » Fri 7. Jul 2017, 12:06
Same again now with creator update (10.07.2017)
I did a rollback to solve the problem...but that´s not a good solution.
"No Brain, No Pain"
asticher
Images: 20
Postby asticher » Fri 26. Jan 2018, 16:43
Update: ReInstall in user default e.g.
C:\Users\xxx\X-Sim\
dir and it works again! Thanks Sirnoname!
"No Brain, No Pain"
asticher
Images: 20
Postby asticher » Thu 21. Jun 2018, 14:29
Problem is still not solved for some Plugins.
If LockOn or the DCS Plugin is used the Extractor start only once.
After rebooting it hung @ "Get last profil".
After clearing profil (no plugin used) the extrator runs perfekt.
Install in C:\Users\xxx\X-Sim\ won´t change anything.
Also deleted all other plugins und wizard scripts, no solution.
Admin rights are set on all x-sim files.
Testet on Win10 with Fall and Spring Update.
Without the win10 updates the extractor works - but this is Dead End.
"No Brain, No Pain"
asticher
Images: 20
Return to Report a bug
