[Fixed]login-logout
Report bugs regarding the forum & website (this forum is closed! please use the bugtracker instead)
[Fixed]login-logout
Postby vicpopo » Fri 6. Jul 2012, 22:07
Hi ,
I've got some problems for login with the new forum (for the old forum taht works)
I put my username and password , I've been login successfull and then the browser go back to the forum automatic and I 'm logout doing anythig !!
That happens with :
Macbook with Camino web browser
It works with safari,firefox
Ipad : that doesn't work with safari , puffin :evil:
Regards
Gilles
Re: login-logout
Postby value1 » Fri 6. Jul 2012, 22:51
same here. obviously this doesn't happen always ;)
but I can edit a post now :D
value1
Images: 3
Has thanked: 12 times
Re: login-logout
Postby floriske » Sat 7. Jul 2012, 01:18
Did you try clearing your browser cache/cookies?
There was a cookie problem that had to be fixed that might be causing this (mentioned on the portal as well)
floriske
Images: 96
Re: login-logout
Postby value1 » Sat 7. Jul 2012, 07:22
Thank you floriske! Deleting the cookies resolved the problem.
value1
Images: 3
Re: login-logout
Postby vicpopo » Sat 7. Jul 2012, 09:45
floriske wrote:Did you try clearing your browser cache/cookies?
hi,
ok I saw this information on the portal and now it works !
thanks
Return to Report a bug
