PololuMini Maestro 12-Channel USB Servo Controller
Topics and questions about other X-Sim compatible hardware
Postby kenneth » Sat 6. Jul 2013, 14:14
I have two of thees units one working the 6 channel item but I am running the old x sim software on it i have the new software with the same setting on it but I just cannot get it responding to any thing. I works perfectly fine using the Mistro software but not x sim.
the 12 way is running on a new PC
Setup
comport
Pololu Mini Maestro 12-Channel USB Servo Controller TTL Port on com 6
Pololu Mini Maestro 12-Channel USB Servo Controller Command Port com 5
Axis = ~a1~ value 1 1
Edited entity Com 5
Speed 115200 8 noparity onetop bit
Sim start ~255~~0~~a01~~255~~11~~a02~
axis infomation ~255~~0~~a01~~255~~11~~a02~
Sim Stop ~255~~0~~a01~~255~~11~~a02~
Please can you help
kenneth
Images: 14
Re: PololuMini Maestro 12-Channel USB Servo Controller
Postby sirnoname » Sat 6. Jul 2013, 16:49
-uncheck all other interface plugins
-verify USO is sending with the free serial port monitor
Postby kenneth » Tue 9. Jul 2013, 19:32
I have unloaded all interface no improvment
I have loaded on another PC I am running both on the same PC
I see the comunication between the software and the card the green cominucation led on the card starts to flicker when I start the software .
still no joy no servo movment
kenneth
Images: 14
Postby kenneth » Tue 13. Aug 2013, 22:55
Hi I have now got it working it was the setting of the card in the pololu software configuration file i had it incorectly set to uart and not usb
kenneth
Images: 14
Postby sirnoname » Tue 13. Aug 2013, 23:33
Perhaps you can make a post in the interface gallery:
http://www.x-sim.de/software.php?lang=e ... peripheral
With some pictures and setup informations?
Return to Other X-sim compatible hardware
