Frex hyper axis 100
Frex hyper axis 100
Postby schindluder » Sun 23. Aug 2015, 15:04
hello all,
i'm going to build a 3dof motion sim, and now i'm searching for the right actuators. first i wanted to buy 3 scn 6 150 from frex (because of the low price), but then i saw this:
HyperAXIS100
Strong Lifting Power and Hi Speed Custom Actuator
Lifting capacy 100Kg
Stroke 100mm
unfortunately there's nothing said about the speed of this actuators - only hi speed... does anybody know how good they are? are 100 mm enough for good motion (i would take them just for the seat)?
thanks in advance
schindluder
Re: Frex hyper axis 100
Postby sirnoname » Sun 23. Aug 2015, 15:55
150mm/s + continous work are the points
Postby schindluder » Sun 23. Aug 2015, 17:07
that means they will keep the speed under load? would you recommend them, or are the scn6 good enough. i'm also afraid that 100mm are not enough for the seat.
schindluder
Postby sirnoname » Sun 23. Aug 2015, 18:37
For example: frex 100mm, used ~80mm to avoid end contact, 400mm/s -> 150mm/s under load. 24hrs, 7 days. recirculating ball instead of nuts.
Many use 150 but I do not think it is usefull. SCN6 are many times slower but needed for person > 90kg
Return to Actuators
