Any other comments or suggestions ?
Yes, use the shown 3-10-100 timing setup!
The response means that there is a communication problem with one zero leading because of timing problems.
It does not look bad but the leading zero is a problem.
mereni wrote:As you can guess, I do not use a proxy, so I can't fix that ! I consequently guess I will have to use the offline version. If I understand well, this requires a key.
In my mind, my project is too complicated and costly to deserve a Project Page, but I obviously have no objection to a donation, on the opposite. In that case, what is the exactly the process and how much does it cost ?
