Problem whit pololu jrk 21v3 and converter
Postby graw78 » Sun 19. May 2013, 09:00
Hello everyone I'm Simone.I am Italian and use google to translate.
I purchased two jrk Pololu 21v3 and I installed the drivers.
are in the process of design and early testing and already 'I have a problem.
the pc recognizes them
after I created an axis in x-sim converter
and after that I set the jrk in x-sim
as you can see in the list appears pololu jrk
so far so good. I followed to the letter to set the guide on youtube of BSFT.
Now the problems begin.
I go into interface setting
i click start HW rescan and..................
in all outputs of found interface does not appear pololu jrk!!!!!!!!!!
HELP PLEASE!!!!!!!!!
'cause does not come out in the lists?
graw78
Re: Problem whit pololu jrk 21v3 and converter
Postby sirnoname » Sun 19. May 2013, 09:13
1. remove all entries in USO
2. Download and install this plugin (copy to interface plugins):
viewtopic.php?t=673
Do not use older plugins!
Postby graw78 » Sun 19. May 2013, 09:25
Hello Sir thanks.
I put your plugin.
Now I have done as you say with the values ​​USE but still no go and now I also returns this.
Last night he did not
graw78
Postby yokoyoko » Sun 19. May 2013, 10:44
Hi I don't understand this sentence but perhaps this video will help you with your problem?! (don't forget to "clear" all uso settings and com-ports - just use the interface and not the uso)
EDIT: if the interface section does not show the pololus after a hardware rescan - please restart your pc and the convertor and try again.
Best regards
Postby graw78 » Sun 19. May 2013, 10:59
thank you guys are unbelievable.
I have responded with the speed 'of light.
like superman:-D.
I've been all night in front of the pc and today 4 hours.
I'm going to rest.
however I have made ​​great strides today, thanks to your help.
Tomorrow I get the power supply and resume working.
thanks for *
I adore you!!
this and 'my passion and you are fabulous!
graw78
Postby yokoyoko » Sun 19. May 2013, 11:10
if I look at your screenshot I would suggest to use higher max. values or the auto-max detection. You have very high peaks in the math-row (blue line). Try to reach the top only at max forces on track.
Br
Postby sirnoname » Sun 19. May 2013, 12:13
Your comport error in the second picture say: you did not this step!
Postby sirnoname » Sun 19. May 2013, 12:15
Hi yokoyoko, which plugin are you currently using? Dave told me the one with the latest download does not work.
Postby yokoyoko » Sun 19. May 2013, 14:13
Hi Sir,
how can i find out what version I am using?
It has the "änderungsdatum" = 23.02.13 , does this help you?
edit: I use the x-sim version 3.0.1.4 and did not change the plugin.?
Postby graw78 » Sun 19. May 2013, 14:15
RE:
Hi Sir.
I tried but the problem 'remained. Let me make a small step at a time. I find it hard to understand the use of x-sim. not 'simple
Tank you
graw78
