50A Dual-channel H bridge Motor Drive Module for A
Postby alejandr737 » Sun 27. Jan 2013, 12:45
Hi could connect this bridge to a K8055??
http://www.ebay.com/itm/50A-Dual-channe ... 4cfae8c855
or only for arduino?
alejandr737
Re: 50A Dual-channel H bridge Motor Drive Module for A
Postby sirnoname » Sun 27. Jan 2013, 12:59
Not fixed but simple upgrade to a arduino for 17€ and you get a better result with the firmware here in the forum.
http://www.x-sim.de/software.php?lang=e ... rs_drivers
Sell your k8055d on eBay to get the money back.
Postby alejandr737 » Sun 27. Jan 2013, 21:17
buy this bridge and an Arduino Mega 2560, before knowing this forum
arduino code but it was very difficult for me, I decided to buy a K8055
to get by with it, and when controlling the arduino put
regardless of the controller you use, can you tell me the connections h bridge
thanks
alejandr737
Postby Roadster2 » Tue 29. Jan 2013, 01:44
The eBay Seller that you linked to for this board states in their description "50A for each channel/motor". However, other eBay Seller's that are offering the same product simply state "Rated Current: 50A" i.e. 25A per channel. It might be worth checking this with the Seller if you need more than 25A per motor.
Roadster2
Postby alejandr737 » Wed 30. Jan 2013, 14:06
thanks for the answers
buy this bridge because the seller said is compatible with arduino
excuse my ignorance I'm new to the topic
EN= 1 that means? you have to connect the ping?
and
EN=0 not to connect?
and vacant?
besides I have a arduino mega K8055, if I can not connect this bridge, appreciate advise me one similar and it was easy to connect to the Arduino Mega 2560
alejandr737
Postby alejandr737 » Wed 30. Jan 2013, 17:47
Thanks for responding, that h-bridge advise me
alejandr737
