SMC LECP6 Linear Actuators compatibility
Postby nsochala » Mon 11. Dec 2017, 17:46
Hello,
I would like to know if it is possible to use x-sim with Linear Actuators smcusa with the LECP6 serial communication.
Best regards,
Nicolas
LEC-OM02201 bus_EN Modbus RTU RS485.pdf
(514.7 KiB) Downloaded 1403 times
nsochala
Re: SMC LECP6 Linear Actuators compatibility
Postby sirnoname » Wed 13. Dec 2017, 08:29
Why not, the interface plugins are open source.
Postby nsochala » Thu 14. Dec 2017, 16:14
Thank you for you answer.
I found this information about the interface plugin :
http://www.x-sim.de/manual/interface.html
Extract 'You will find two sample source codes.', I don't find it .
Could you tell me where I can find the informations to write the interface plugin?
Best regards,
Nicolas
nsochala
Postby sirnoname » Sat 16. Dec 2017, 16:50
Other stuff folder.
