H-bridge - Another one from ebay
Postby denyszandonadi » Fri 22. Jan 2016, 09:51
Does anyone tested this H-bridges? This look well designed for me, but i cant find anything on internet that talk about this product.
The first can handle 100A and the second 60A.
Thank you for any answer!
denyszandonadi
Re: H-bridge - Another one from ebay
Postby sirnoname » Fri 22. Jan 2016, 19:56
Datasheet and pinout!
Postby denyszandonadi » Sat 23. Jan 2016, 02:12
Sorry, my bad!
The only information i have is this one:
1, the basic components of the drive module body placement, highly integrated, well-designed board layout, very beautiful, very small, onboard two-way high-power DC motor drive, the drive module size of only 70mm * 56mm;
2, large heat sink at high currents can effectively drive module for cooling, maintain good and stable performance of the module;
3, when the drive motor, the module maximum rated current up to 60A, and conduction only 0.003 ohm resistor;
4, the switching frequency is high, the most up to 60KHZ, thus effectively avoiding the low frequency of commissioning motor brings unpleasant;
5, the control interface is very simple: A1.A2 = 0.0 when the brakes; when A1.A2 = 1.0 for forward; A1.A2 = 0.1 when reversing; PA for PWM wave input (motor speed adjustment); G for the Dashboard common ground pin (B road for the same control);
6.3.3V/5V compatible, and only need 1 channel motor power supply 12~30V
This is the link for 60A:
http://www.ebay.com/itm/60A-High-Power- ... SwZd1VXqPv
And this for 100A:
http://www.ebay.com/itm/100A-High-Power ... Swv-NWXXoB
Thank you!
denyszandonadi
Postby sirnoname » Sat 23. Jan 2016, 13:54
If you read the datasheets of the IC's mounted on this bridges you get the info that 60A is only for short usage.
This means this bridge can handle about 30-40A effective and if you use a bigger heatsink or fan.
So you must find a picture or info about the used MOSFETs on this board to be sure.
The bridge has all pinouts for usage with Arduino XPID firmware.
Postby sirnoname » Sat 23. Jan 2016, 13:58
By the way, if you do not buy a complete controler with bridge, you should buy some more bridges, else you may burn one and then wait for the spare part.
