help pls with arduino uno r3 and moto monster sh  Topic is solved solved with post #9663
Postby dradis700 » Tue 27. Aug 2013, 23:48
i just installed everything n wanne do a test
installed wiper motors
the potmeters
the arduino shield
the moto monster shield
the power supply
can anyone send me a code pls just to test it
i dun know where to start
kindly regards dradis
dradis700
Images: 35
Re: help pls with arduino uno r3 and moto monster sh
Postby RacingMat » Wed 28. Aug 2013, 09:11
Hi Dradis !
Good !
I advise you to follow the step-by-step instructions of my tutorial http://www.x-sim.de/forum/viewtopic.php?f=37&t=943
Is your Arduino installed in windows ? is the Com Port setup ? can you upload example sketches ?
The code is in the topic as well.
Once installed and loaded, you will be able to send instructions to Arduino and Motors
For beginning, start by sending yourself instructions to the Arduino and to your motors...
No need at this stage to use Xsim and Game's data !
In the "Serial Monitor" send the following strings in Hexa and Enter:
R7FL7F
-> it should move the playseat in horizontal position
R64L64
R3FL3F
R01L01 (max !!)
-> it should tilt the playseat backward and a bit further
R9BL9B
RC1LC1
RFFLFF (Max !!)
-> it should tilt the playseat forward and a bit further
You can mix for rolling mouvment :
R3FLC1
R01LFF (Max !!)
-> roll left
RC1L3F
RFFL01 (Max !!)
-> roll right
Can you share some pics ?
Yours
Mat
Postby dradis700 » Wed 28. Aug 2013, 21:52
first of all many thx for your very fast reply mat
i installed the code and the motors worked for maybe 0.5 sec
everything looked ok thx to u mat
so i know now the powersupply is not powerful enough.
so few days ago it was the same but the motors did nt move at all.
so i upload a few pics
dradis700
Images: 35
Postby RacingMat » Thu 29. Aug 2013, 10:25
dradis700 wrote:the powersupply is a dell nps650AB A
regards
This PSU is only 17A for 12V... it's too weak indeed !
You'll have to look for stronger PSU ;) around 40 A
Mat
Postby vicpopo » Thu 29. Aug 2013, 10:58
Hi ,
If you have a car battery you can test with it waiting for a stronger PSU. ;)
You can also use both in paralel ....
Postby dradis700 » Thu 29. Aug 2013, 22:50
thats what i thought
so many thx guys
i ll appreciate
have a nice weekend
regards dradis
dradis700
Images: 35
Postby erikeasu » Wed 20. Nov 2013, 04:31
I'm kind of in the same boat. I have a joyrider off thanos design with wiper motors and pulley system. Have an arduino uno and a moto monster though. I used your code and it works with the pots. But I can't get it to stop when the pots stop. Please help
Erik e
erikeasu
Postby Tombo » Wed 20. Nov 2013, 19:53
have you tried to reverse the motorcables? Does it work with pot not mounted directly to the motor?
Tombo
Images: 36
Postby RacingMat » Thu 21. Nov 2013, 12:00
erikeasu wrote:I have a joyrider off thanos design with wiper motors and pulley system. Have an arduino uno and a moto monster though. I used your code and it works with the pots. But I can't get it to stop when the pots stop.
Hi Erikeasu!
Did you follow the steps I indicated here first hardware tests and trials?
what did you succeed? where are you stuck?
yours
Mat
Postby erikeasu » Fri 22. Nov 2013, 19:13
Racingmat,
yes I did try your steps, and have it turning nonstop, but then I cant seem to get it to stop when it is suppose to, when you say "check the wiring" what do I need to check, and reverse which wires, the pots, or motor. my wiper motor has 5 wires with the original plug from the truck I pulled it from. I am only using two wires. the purple(high speed) and the ground(black wire) there is a yellow(low speed) and a red and brown that I didn't hook up. when I tried it to a battery the only wires that did anything was purple yellow and black. sorry to be so dumb about this, its all so overwhelming to a newbie. Im not trying to hijack this post either, just need some desperate advice.
thanks a lot.
erik
when I enter the serial commands it doesn't seem to do anything but keep turning unless I move the pot to the middle, which it stops. my comports are correct. I am using one pc also. its a custom I5 8gb with NVidia 650.
please be patient with my ignorance on this
erikeasu
