Noob question: 300A Brushed ESC can be used?
Postby alexandrelopes » Sat 13. Jul 2013, 21:04
It would be possible to use controllers speeds, for cars R / C 300A in place of H-bridges?
These controllers work in pwm, revolve for the two sides, and some models support 12 volts.
Based on this: Work as H-bridge to control wiper motors?
Especifications:
SKU rcvp3310001
Motor Type Brushed
Forward Current (A) 300
Forward Burst Current (A)
Reverse Current (A) 150
Input Voltage (v) 9
Max. Input Voltage (v) 14.8
BEC Max 2A / 5.6V
Programmable Yes
Fan Heatsink Yes
Water Cooling No
Dimension (mm) 45 x 32 x 43mm
Net Weight (kg) 0.086
Cross Weight (kg) 0.1
http://www.ebay.com.au/itm/1-10-RC-Car- ... 4d09c75f50
alexandrelopes
Re: Noob question: 300A Brushed ESC can be used?
Postby RacingMat » Wed 2. Oct 2013, 22:34
Hello Alexanderlopes!
Yes, this looks to be a usable Hbridge: I wanted to check further but the ebay link isn't available anymore...
What was the price?
Did you started your project? :-)
Mat
Postby martinberger » Wed 28. May 2014, 11:10
Hi alexandrelopes
am i right, this is a normal rc car ESC?
how do you wire this "Bridge"
Do you use an arduino? What sort of code...
regards,
Martin
martinberger
