AAA-High Power Motor DC
Postby digmablass » Mon 1. Jul 2013, 22:14
Hi guys...
I'm testing a starter motor of motorcycle, has a high torque, the problem is handle the current of this motor, I need a H-Bridge driver controller of 100 Amp aprox. to move it, dear sirnoname what do you think about of this it?, you think that can move an linear actuator?
starter motor motorcycle
digmablass
Re: AAA-High Power Motor DC
Postby ferslash » Mon 1. Jul 2013, 22:42
man i am not an electronic guy. but,...
as far as i understood, the current measured in amps from a motor, refears to the power that the motor "sucks" out of your power source when "it is working at a full load", so your motor may need 100amps to work as a engine starter when it has to move a whole bike engine... but i may need less current when it has to move you in a sim... if you have the motor with you, you should make a test, and try to measure how many current does the motor "sucks" when you load it with some kgs.
best regards
fer
ferslash
