Postby fooons » Sat 13. Oct 2012, 13:28
thecure wrote:where did you buy IR2110 ? can you give me the link?---tks
I have adquired mines from:
http://es.rs-online.com/web/c/?sra=oss& ... 10&x=0&y=0
Choose your location if not from Spain.
Regards fooons
fooons
Postby thecure » Sat 13. Oct 2012, 13:37
http://it.rs-online.com/web/c/?sra=oss& ... 10&x=0&y=0 are equal?
P.s: but you must have a VAT ? do not sell to private
thecure
Been thanked: 5 times
Postby fooons » Sat 13. Oct 2012, 13:43
thecure wrote:http://it.rs-online.com/web/c/?sra=oss&searchTerm=ir2110&x=0&y=0 are equal?
Yes, you should choose the through hole mount type, (2,66€) other is surface mount.
I adquired lot of parts and no VAT number needed here in Spain. Only taxes.
Regards fooons
fooons
Postby thecure » Sat 13. Oct 2012, 13:48
in italy .YES :? ...but I found it on ebay :D tks
thecure
Postby fooons » Sat 13. Oct 2012, 13:51
:) ebay is always a good solution.
Regards fooons
fooons
Postby vicpopo » Sat 13. Oct 2012, 17:33
Hi ,
I bought components on Farnell in France.It's not cheap , the shipping cost is not given but the service always 100% garantee.
The delivery shipping is maximum 48 h00 ( it's the reason why it' s expensive) :roll:
Best Regards
Postby thecure » Sat 13. Oct 2012, 18:46
Farnell aussi recquiert TAV ! :D
thecure
Postby speedy » Sun 14. Oct 2012, 08:45
I'm sorry guys ... Actually these component's aren't that much cutting edge tech. and couldn't be found ... I bought every thing locally here from the electronics shops ... like this one in Egypt, Cairo ...
http://www.ekt2.com/ekt/prodList.asp or this ... they are Farnell local partners .
http://www.gs.com.eg/index.php
Try to find out if there is any local stores in different cities than yours in your country that can deliver the needed parts ... plus we all pay taxes . :x
:arrow: search in Yellow Pages :idea:
:arrow: essayez les pages jaunes :idea:
speedy
Has thanked: 14 times
Postby thecure » Sun 14. Oct 2012, 10:56
I found everything you need... :D ;) tsk
thecure
Postby speedy » Mon 15. Oct 2012, 03:36
Good day every one ...
>>>>> Post is updated .. every thing is Ok now ...<<<<<
Please note that I added 1x 680Ohm resistor and two more red color LEDs ... these will be used as direction indicator to make you see if the motor is running in forward or reverse direction .
as described earlier error fixed ... I guess I didn't save the final touches for this H-bridge when making it ... when decided to publish it ... the files had that missed touch that Vicpopo found ... sorry vicpopo :oops: ...
Now it is recommended to use two of a single layer boards ... mounted back to back as described in first post .
as Vicpopo did his H-bridge on a double layer board ... good Idea ... but he will face difficulties un mounting all these MOSFET's if something happens [Pls. don't make it happens] .
thanks and best regards
spe ;) edy
speedy
