Dimension Engineering Position Control Module
Re: Dimension Engineering Position Control Module
Postby Mertensbart20 » Sun 2. Mar 2014, 12:09
Hello Terry,
I haven't got the describe software hooked. It did try using a carbattery as powersupply (with and without charger) and I have the same result: the sabertooth 2x25 works fine, the Syren10 gives a fault.
I hope dimensionengineering has a solution but I am starting to think the syren10 doesn't work with the kangaroo x2 (according to their site it should). Normally I wouldn't consider this a problem and just buy a sabertooth. But I am a teacher electrical engineering and a few months my school bought 6 syren10's for the students. So it just ordering sabertooth is not an option :-) .
Should I finf a solution I'll let you *
Thanks for the advice,
Bart
Mertensbart20
Postby telfel » Sun 2. Mar 2014, 18:06
Hi Bart
Not sure how the address setup works without DEScribe?
When the Sysren runs as on its own as a speed controller you set address via dip switches, those dips are changed to suit the Kangaroo,
can you hook up to describe to check the address? The auto-tune can then be set within the sw tool.
Regards Terry
telfel
Images: 54
Been thanked: 9 times
Postby Mertensbart20 » Tue 4. Mar 2014, 20:42
Hello Terry,
Just for your information. The problem with the Syren10 was that it had an old firmware. I send the syren10's to dimension engineering where they will flash the new firmware. The MFG date of the syren10 needs to be at least 18/13 or later.
And handy to know that the kangaroo x2 can count 200 000 pulses per second.
Greetings,
Bart
Mertensbart20
