Dimension Engineering Position Control Module
Re: Dimension Engineering Position Control Module
Postby DannyT » Wed 16. Oct 2013, 15:49
Ok. but do you really Need the Limit switches?
Because if you auto tuned the Kangoroo the system knows the max and min position.
Rgds
Danny
DannyT
Postby telfel » Wed 16. Oct 2013, 20:30
DannyT wrote:Ok. but do you really Need the Limit switches?
Rgds
Danny
I think you will find the position auto tune applies to wheeled robots, with encoders, you push the robot forward and back,
The auto tune with limit switches moves the motor small amounts forward and back, and then drives the motor to the limit positions. and then returns to the mid position.
The other reason i'm testing with limits is you have a safety system if you get a runaway fault.
regards Terry
telfel
Images: 54
Been thanked: 9 times
Postby Niko » Fri 15. Nov 2013, 00:44
Hello,
how do you program in X-sim (output setting) to control Kangaroo X2? (i was a K8055 user).
Niko
Postby telfel » Fri 15. Nov 2013, 08:58
Select Kangaroo in the Interface settings plugins menu
with the roo connected the com port number and the two channels will appear in the All outputs of found interfaces,
the plugin also shows any faults with the roo in this table.
you can then assign your axis to outputs as with the K8055
regards Terry
telfel
Images: 54
Postby Niko » Fri 15. Nov 2013, 19:56
Hello,
i have no Kangaroo input into "Interface setting".
Niko
Postby telfel » Fri 15. Nov 2013, 20:05
Do you have the Kangaroo in the tick box list All found interface Plugins ?
telfel
Images: 54
Postby Niko » Fri 15. Nov 2013, 20:18
No.
Niko
Postby telfel » Fri 15. Nov 2013, 20:47
You may need to instal the latest version of x-sim
telfel
Images: 54
Postby Niko » Sun 17. Nov 2013, 16:27
ok with the latest software i have now the Kangaroo in the tick box of "all interface plugins",
but not on "all output of found interface"s so i can't choose it.
Niko
Postby sirnoname » Sun 17. Nov 2013, 17:00
Then your wiring is incorrect.
