Tronic H-bridge
Re: Tronic H-bridge
Postby Pablo » Tue 21. May 2013, 22:38
The engines do not need as much power if the structure is balanced ... if it works with the atx power -supply try again a car battery
The wipermotors are 12 V ?
Pablo
Images: 2
Re: Tronic H-bridge
Postby TheXRacer » Tue 21. May 2013, 22:41
Yes the wipers are 12v 45watts , the car battery have the same volts 12V 35Ah
regards
Chris
TheXRacer
Images: 9
Has thanked: 5 times
Re: Tronic H-bridge
Postby Pablo » Tue 21. May 2013, 22:48
I use some similar wipermotors with a 650 W ATX power supply.
With your battery would have to work well, try again ..
Pablo
Images: 2
Re: Tronic H-bridge
Postby TheXRacer » Tue 21. May 2013, 22:58
Unfortunately, it works with the car baterie short LED flashes briefly then goes from the H-bridge ( no funktion) .
...... :roll:
TheXRacer
Images: 9
Re: Tronic H-bridge
Postby TheXRacer » Tue 21. May 2013, 23:06
OK I switching to my ATX Power supply it works with this ! I have any Answer why not with my CAar battery :o ????????
The next big Prob i have the motors lose much power , can anybody help my to solved this ?
Big thanks go to Pablo !!!
best regards
Chris
TheXRacer
Images: 9
Re: Tronic H-bridge
Postby TheXRacer » Tue 21. May 2013, 23:13
Thanos do you can help my PLEASE !!! ????
regards
Chris
TheXRacer
Images: 9
Re: Tronic H-bridge
Postby tronicgr » Tue 21. May 2013, 23:19
There are many factors that make you h-bridge not work.
Some of them include non-isolated motors, too little resistance in DC motor coil, or even just if you grounded the car battery with the wiper motor(No ground is required, in fact its bad!!)
Re: Tronic H-bridge
Postby TheXRacer » Tue 21. May 2013, 23:24
Thank you ,
you can give my some tipps i will chacked it , and i can give you a feedback ;) .
what can i make to show you what is the reason to will the H-Bridge don´t work ?
Pictures, Videos or what kind of presentation my hardware Problem ?
regards
Chris
TheXRacer
Images: 9
Re: Tronic H-bridge
Postby tronicgr » Tue 21. May 2013, 23:34
Some detailed photos of the connections, the motor, the h-bridge... And if possible video of what happens when you connect the motor on the h-bridge...
Re: Tronic H-bridge
Postby RafBR » Wed 7. Aug 2013, 18:35
Suddenly my dsmhb started to burn mosfets again. The same setup that was working for more than a year long. :(
Thanos, can a failure in the pwm or direction from AMC cause the h-bridge to fry or can I discard this possibility?
By the way my dsmhb worked for a long time with IRLZ44N mosfets.
They are very expensive and were not available yesterday on the stores near here.
So I might have one or another IRF3205 that I will test with the "Simple mosfet tester" that I am going to assemble today. If they are ok I will try on the HB.
Also I bought two IRLZ24N mosfets (I know its only 18A continuous, I will try 10A fuses) because it was the only available.
I will stick running some tests and will post the results here. ;)
My regards!
RafBR
Images: 24
