Postby thecure » Sat 20. Oct 2012, 19:38
I speedy, i have a problem :x ....whatch my tread here viewtopic.php?f=37&t=273&start=80 tks :D
thecure
Been thanked: 5 times
Postby speedy » Sun 21. Oct 2012, 05:02
Hi thecure :
Surely you have many disconnected track ... I suggest to put tin on all these weak tracks to see where the cuts are ? ...
Next time please ... upload pictures into this site as the other site is reported to my firewall as harmful and blocked ... I didn't see the details of your DIY board ...!!!
regards
spe ;) edy
speedy
Has thanked: 14 times
Postby thecure » Wed 24. Oct 2012, 15:26
So I connected the cables (see photo) .. right? .... Before connecting the motor, I connected the tester, but does not seem to (see video)
http://www.youtube.com/watch?v=A0XDn6U3 ... e=youtu.be
Then I connected the motor but does this ... see the video P.S: but in theory it should turn on an LED for each direction?
http://www.youtube.com/watch?v=1Ljwjy6H ... e=youtu.be
thecure
Postby mcdonald » Wed 31. Oct 2012, 14:42
Hi thecure :
Good job ... please give me a pictures of the top board with MOSFET's .
- about the direction led ... I guess one of them is reverse installed ...
- about the noisy operation try to replace the feedback pot ... it seems that it has a defective aria ... makes the motor stops and doesn't have a direction to go to .
mcdonald
Postby thecure » Wed 31. Oct 2012, 18:16
for the led i have wrong solder (now are fine) ....... I changed the potentiometer but I get the same error
thecure
Postby denizelmas » Thu 29. Nov 2012, 20:46
speedy wrote:Hi Thanos ....
Congrats for your new home ... ;)
Congrats every one from UK for that magnificent Olympic opening ceremony .Awesome 8-) and it can't be more beautiful
How is that big long Chimneys came out of the stadium earth ????? :?:
BTW ...Thanos :this is really small dimensions you want for high Amps DIY motor controller ...
If you're really talking a bout a "5mmx5mm" even if you're talking about "50mmx50mm" ...
my board is 9.5x10 cm ... for one 50A DC motor ... higher rating is bigger ... but I've got your point ;) .
The HIP4081AIPZ driver chip is a peace of art for technology lovers and a peace of luxury not every one can have it ...
forgive those people like me how can't have a double layer boards or a nearby board etching service .
I'm simply can't buy anything from eBay .It will cost me more than making it like a dinosaur .
There are some people that are beyond last week :lol: "Discovery channel ".
I feel the same here in Turkey, we are almost on the same bot, :evil: thank you for your great efforts
Mind Before Money,Creativity Before investment
denizelmas
Images: 16
Postby denizelmas » Thu 29. Nov 2012, 20:47
denizelmas
Images: 16
Postby denizelmas » Fri 30. Nov 2012, 21:46
speedy, seems great work,
I will study your post (at least 3 more) to consider to make my selves, I am absolutely a beginner and like to do DIY bases, can I count on your help?? :?:
denizelmas
Images: 16
Postby telfel » Wed 13. Feb 2013, 19:03
Hi Vicpopo
As Speedy doesnt seem to be about
Is your H bridge still working and would you recommend the build, looking for a high current board to run 24v 650watt motors with an Arduino
regards Terry
telfel
Images: 54
Been thanked: 9 times
Postby vicpopo » Wed 13. Feb 2013, 19:46
Hi Telfel,
It doesn't work but that comes not from the conception , I burned it with bigworm motor (12 V , 190 Watt) and amc1.6.In fact these motors has got a very low impedance, I measured 0,7 Ohm.
The first positioning at starting ( starting xsim) the amc ask full power. That means the h-bridge starts on the short circuit.
I burned several h-bridges and this one also.
But Speedy said and I agree with , that this h-bridge can handle very powerfull motors.I didn't test it with 24 volts.
The h-bridge is not easy to solder .Before taking your decison look at Pololu drivers also.You can contact Prilad he could maybe try to contact Speedy for you.
Best Regards
